997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
Hughb
PostPosted: Wed Jul 17, 2019 11:14 pm    Post subject: 'Remote' not working on second key -Can anyone help/clarify? Reply with quote
Hi.. 996 C2 2003
Have all 3 keys .... 2 X two button fobs plus 1x grey (no buttons) key
All keys open and start the car.
The problem is that the second (spare) remote does not work remotely!
From my extensive research on the subject it appears that the car may have forgotten this remote through lack of use .. More than 256 presses difference etc.
I have tried so many 'offerings' from the postings of others on this and other websites.... Holding down buttons whilst in/out of door/ignition, turning/not turning, reinserting ....aargh ..getting frustrated.
Has anyone experienced this exact same situation, ie non working remote on second key? ....... Surely not that unusual.
Local OPC suggesting something really simple like holding button down and unlocking car door ....(did not work).. Or else was quoting £Hundreds for new blade, plus PCB plus programming fee.
Would really appreciate anyone's suggestions (even if I have seen them before!) or am I in need of some programming device input ..... OPC only offered expensive option above.
... Have changed battery, reversed battery for a minute, etc
Any ideas?
kurlykris
PostPosted: Wed Jul 17, 2019 11:23 pm    Post subject: Reply with quote
Try reading here Thumb
http://www.jmgporsche.co.uk/index.php/menu-articles/articles-maintenance/item/234-996-986-alarm-primer
2006 987.1 Boxster S 3.2 sport chrono
2010 Mercedes E350 AMG Sport
Hughb
PostPosted: Thu Jul 18, 2019 12:02 am    Post subject: Keys Reply with quote
That's a pretty definitive article ........ And leads me to think that I might be in the category of being so far out of synch that I am past recovery Sad
I have actually seen the 10 step resynch guide already and tried it .... Even though it does not say when to release the button at the very end ( before or after removing key from lock?). I'm going to try it again anyway!
Many thanks for this link ..... Kurlykris
To anyone with a similar problem .... This is the 'GOTO' article.
kurlykris
PostPosted: Thu Jul 18, 2019 12:16 am    Post subject: Reply with quote
Sometimes you have to try the procedure 5,6 or more times for it to work, trust me I have this kind of thing with my work and sometimes going for a cup of coffee and a bit of time away from the issue works wonders Grin
PostPosted: Thu Jul 18, 2019 7:16 pm    Post subject: Reply with quote
Try the routines listed as you never know ..
I'm afraid in my experience it will be a new fob is required as its out of sync .
The third key btw is the valet key .. very few owners still have these .
It's what you used to give to the garage when working on your car or an emergency spare .
No remote .. you use the door lock .
Indy Mechanic .
DAVIDGT996
PostPosted: Sun Jul 21, 2019 10:35 am    Post subject: New fob Reply with quote
Had the same problem with the one key that came with the car.
Tried all the re synching suggestions but none worked. Had to order new head from OPC and then had Terry @ Autostrasse code the new head to the car (top man did it FOC!)
2001 C2 Coupe Tip
Black, GT3 kit, lowered
996driver
PostPosted: Sun Jul 21, 2019 7:48 pm    Post subject: Reply with quote
I had a similar problem with my 1998 C2. When I bought it I was told that it hadn't been working for at least 7 years since before the last owner got it. I put new battery in with no joy when I got the car in May but hadn't done any more until today. I followed the guides to reset with battery reversed and then did the ignition reset which amazingly worked!
However the second key still doesn't work. After taking the key apart I can see why, the button microswitch connection on the circuit board is missing! So before you start looking for other issues I'd recommend making sure that everything is present.
I understand that you can buy the microswitches but at least I have one key working and don't need to rush to put key in ignition now!
1998 911 Carerra 2 Manual Coupe in blue
Previously :
1986 944 2.5 Lux
2001 911 Carrera 2 Manual Coupe in silver
https://porsche911owner.blogspot.com/
Hughb
PostPosted: Sun Jul 21, 2019 9:32 pm    Post subject: Reply with quote
Hi 996driver
So pleased that this thread has produced some positive result.
I think I am still relegated to the 'forever out of synch' situation with my second key.
I have had it apart, changed battery, reversed battery, followed all resynch instructions multiple times ..... All to no avail, but hey, I still have a fully functioning 'first key' .... And I actually have the rare, grey valet key.
As a newbie to this forum, in fact forums in general, I am now a confirmed fan...of the way in which knowledge can be shared to the benefit of members.
(Just wish it was my key!!)
kurlykris
PostPosted: Sun Jul 21, 2019 9:46 pm    Post subject: Reply with quote
You could try these people, no fix, no charge Thumb
https://www.ebay.co.uk/itm/273540425988
Marky911
PostPosted: Mon Jul 22, 2019 7:57 am    Post subject: Reply with quote
I messaged those eBay people about mine. Didn’t even get a reply.
Hugh, I have exactly the same issue as you. One working perfectly, one only unlocking the car and starting it but no remote.
I’d just leave it. You only need the spare to get in and start it and they only die when left in a drawer for years.
I’d pay upto £50 to get mine working but anything more that and I’m not going to bother. Crappiest keys ever mind! It’s shocking how often they fail.
I had two one year old keys with my last car along with a receipt for almost £400 for the pair. One died at just over a year old. Total joke. frustrated
wasz
Paul Ricard
1999 Porsche 996 Carrera 2
PostPosted: Mon Jul 22, 2019 8:46 am    Post subject: Reply with quote
I am also doing the ignition shuffle every time I use the car.
My remote works but the battery drains in a few days.
I need to get around to soldering a new micro switch in to see if that fixes it.
996 parts cache sell off
dt4
PostPosted: Mon Jul 22, 2019 10:50 am    Post subject: Reply with quote
I have resolved why my spare key doesn't operate the central locking etc...
I opened the case to do the battery flip and the reset procedure and the case is empty!!
Are new internals available, what would need to be done if they are?
thanks
David
1999 996 3.4 C4
1975 914 1.8
2000 986 2.7
wasz
Paul Ricard
PostPosted: Mon Jul 22, 2019 1:58 pm    Post subject: Reply with quote
LOL!
Yeah you need a new remote key head. You have to buy a new one as it comes with a code attached to a piece of paper that you then have to pay someone with a PIWIS computer and access to Porsche codes to add it into your car.
You can buy a new keyhead from lots of places but only an OPC or a well established indy will be able to get access code for you car from Porsche.
I think OPC charge a min of 1 hour labour but it only takes like 5 minutes to do it....try a good indy.
PostPosted: Mon Jul 22, 2019 6:02 pm    Post subject: Reply with quote
To get the Ipas codes needed to code a new key then you just need to take a V5 into an opc and they will print them off for you .
It is after all Your data .. you just need to prove you own the car is all .
You do need a sensible tester to code it though .. Piwis or Autologic are the only ones i know of .
To be fair some guys on here own a piwis so could code their own keys .
labour at and indy and again an opc should be 0.5 hrs labour .
Indy Mechanic .
dt4
PostPosted: Tue Jul 23, 2019 7:25 am    Post subject: Reply with quote
could someone provide a link to a new fob please, I presume I can use the old blade?
1999 996 3.4 C4
1975 914 1.8
2000 986 2.7
PostPosted: Tue Jul 23, 2019 6:50 pm    Post subject: Reply with quote
The fob as far as i'm aware is OPC only .
You can get the case from ebay but you need to swop over the internal components which in this case you don't have .
The key blade is always swapped over with a replacement fob .. Porsche charge you for a blade separately .
Indy Mechanic .
