997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
Rosselder83
PostPosted: Tue Jul 16, 2019 8:32 pm    Post subject: 996 TT exhaust removal - crusty nuts Reply with quote
Next step of my saga is to remove the exhaust so I can start to remove the turbos. The nuts on the exhaust are almost non existent so I can tell it’s going to be a riot getting them out. Due to the cats it doesn’t look like I can get a socket on them and I’m pretty convinced a spanner isn’t going to cut it.
So I’m looking for suggestions? I spoke to a chap on Instagram and he swore by using a nut splitter, not a tool I’ve ever used so I’d be looking for brand and size recommendations.
Fire it all at me please.
Thanks in advance
Pickse
PostPosted: Tue Jul 16, 2019 9:01 pm    Post subject: Reply with quote
I had the same issue.
The nuts were 13mm across some flats and 10mm across others.
I went with a Draper induction heating tool. https://www.drapertools.com/product/80808/Induction-Heating-Tool-Kit-(1-75kW)
Not cheap and it took a few attempts but finally the nuts glow red and undo easily after that.
Someone later suggested to me the Irwin Nut removers https://www.toolstation.com/irwin-bolt-grip-nut-remover-set/p81815?store=C7&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=EAIaIQobChMIg7juw6i64wIVS7TtCh10Ww2gEAQYASABEgIzF_D_BwE
I bought some but have yet to try them on anything as challenging as those turbo nuts.
If you're anywhere near me, GU52, you're welcome to try the Irwins.
Cheers,
Pickse
03 Arctic Silver 996T Tip S
Now 9E38 - An improved! 996T
heed
PostPosted: Tue Jul 16, 2019 9:50 pm    Post subject: Reply with quote
I’m currently having my mufflers swapped out on my 996. They’re original and everything is knackered. My mobile specialist was using those nut removal sockets. He said they were very good.
'04 996 C4S, arctic silver, graphite grey
Mac996t
2004 Porsche 996 Turbo
PostPosted: Tue Jul 16, 2019 11:52 pm    Post subject: Reply with quote
I did this job on mine quite a few years ago now, the method I used which worked really well was to grind down one side of the nut until it was almost down to the stud then split it using a sharp chisel.
Not only did this get the nut off but it also removed all traces of the nut from the threads of the studs with out damaging then and I was able to reuse the studs.
Mac
Mac996t
PostPosted: Wed Jul 17, 2019 12:03 am    Post subject: Reply with quote
See pic in link below
http://911uk.com/files/cimg0817_460.jpg
http://911uk.com/viewtopic.php?p=1221792&highlight=#1221792
Mac
Rosselder83
PostPosted: Wed Jul 17, 2019 6:00 am    Post subject: Reply with quote
Some top tips in here chaps, thanks very much.
