997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
aware911
PostPosted: Mon Jul 15, 2019 2:02 pm    Post subject: IMS issue? Reply with quote
Well life is weird at times.
Today I met a guy that has the same 997 like mine.
He said that he spent 5000 euros for preventive fix of the IMS.
IMS? What is this? I asked...
He told me enough and then came back at home.
My 997 has 45000 km's only and is sporadically driven approximately once a month.
I looked under the car and saw no leak on the floor but the engine is oily around the area of the seal of the bearing in question.
Any ideas what steps should I follow?
Car has May 2006 as date of production.
Thank you
PostPosted: Mon Jul 15, 2019 3:14 pm    Post subject: Reply with quote
Forget about it.
When you need a new clutch revisit this thread and ask again.
jl-c
PostPosted: Mon Jul 15, 2019 3:57 pm    Post subject: Reply with quote
Alex wrote:
Forget about it.
Yeah, this ^^^^^^^ Smile
aware911
PostPosted: Mon Jul 15, 2019 4:43 pm    Post subject: Reply with quote
Alex wrote:
Forget about it.
Thank you, btw I have auto trnasmission
PostPosted: Mon Jul 15, 2019 5:06 pm    Post subject: Reply with quote
Forget about it.
Worry about bore scoring instead.
PostPosted: Mon Jul 15, 2019 7:17 pm    Post subject: Reply with quote
we rate these leaks on a scale of 1 - 5
1 / Black dirt basically , not a leak but more of a sweat .. no work needed .
2 / Damp , a bit more than misting but no drips forming .. no work needed .
3 / Small drip or obvious oil but not really dripping on the floor .. it is a leak but not bad .. no work needed .
4 / a drip which falls to the floor when on a ramp .. will cause a small patch of oil on the floor when on a ramp ... time to get the seals done .
5 / a continuous leak onto the floor , oil spread around the entire area .. time to not drive the car anymore let alone get the seals done .
IMS .. 2006 is the larger bearing .. i can only say i've never seen one fail and imho it's not worth worrying about .
Btw .. with a tip then its an engine drop to change the seals or the bearing .
Indy Mechanic .
aware911
PostPosted: Tue Jul 16, 2019 4:59 am    Post subject: Reply with quote
Thank you all again.
No dripping at all.
https://drive.google.com/open?id=14gkDv8n6QoL9yxIgXTgIlcdv6sHnBQ2x
PostPosted: Tue Jul 16, 2019 5:41 am    Post subject: Reply with quote
It's good to be aware Grin
aware911
PostPosted: Wed Jul 17, 2019 3:18 pm    Post subject: Reply with quote
For the sake o completness, I assume I am at level 2 in your scale of 1 -5. https://drive.google.com/open?id=14gkDv8n6QoL9yxIgXTgIlcdv6sHnBQ2x
Do you happen to agree?
Thank you
PostPosted: Wed Jul 17, 2019 5:50 pm    Post subject: Reply with quote
From the picture then between a 1 and a 2 .. basically nothing to worry about at all Smile
Indy Mechanic .
aware911
PostPosted: Thu Jul 18, 2019 4:46 pm    Post subject: Reply with quote
Thank you again.
Luckily enough my previous sports car, namely a 986 was too driven very rarely and didn't have issues with IMS... Luckily....
I shall drive my 997 more often though anyway.
