997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
adeymars
PostPosted: Sat Jul 13, 2019 11:13 pm    Post subject: AIr Oil separator 1998 C2 which brand. Reply with quote
I need a new AOS I have seen several brands along with the Porsche OEM item.
The three other manufacturers versions also appear popular which are Uro, Metzger and Retro line has anybody fitted any of these, are they better, same or not so good or is there anything else out there that I'm not seeing?
Or should I stick with OEM?
Please do not be frightened of changing this item yourself, the job content and difficulty of it is blown way out of proportion in my opinion - actually it's a P.O.P.
in comparison to some other jobs Iv'e faced in the past.
Engine lowered. No.
Expansion tank removed. No (Tank only drained and partially unmounted)
Fuel lines removed No.
Bump hat worn Recommended. Thumb
996 C2 Manual
Arctic Silver
Goodyear 's GSD3
Down 10mm
Lloyd 6 Light -Konvertierung..
Paynewright
PostPosted: Sun Jul 14, 2019 2:29 am    Post subject: Reply with quote
POP if the fixing bolts don't shear off because they are seized! Then its engine out!
I asked my indy to change mine (precautionary) when he did the clutch but the bolts felt like they’d snap so he left it for another day!
adeymars
PostPosted: Sun Jul 14, 2019 2:58 am    Post subject: Reply with quote
Mine were tight to break out and sticky all the way but this was down to thread lock, I guess that's factory applied.
I read lots of personal experiences of people changing out their own Aos and nobody reported shearing any. Mines Revision 52 so I'm assuming it's from new and also due to nothing mentioned in my history file.
996 C2 Manual
Arctic Silver
Goodyear 's GSD3
Down 10mm
