997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
LouSlips
PostPosted: Sat Jul 13, 2019 2:26 pm    Post subject: Air con not blowing on face setting Reply with quote
997 climate control unit seems to be working but will not blow air on face setting despite switch appearing to work. Changed central drive flap positioning motor (part 996.573.917.03) but still not blowing air on face setting - air comes out of footwell and dash when foot or dash button selected. When car starts the climate control display flashes 9 or 10 times - not sure if this is a fault code. Any guidance welcomed.
PostPosted: Mon Jul 15, 2019 7:20 pm    Post subject: Reply with quote
i would start with getting a fault code read out of the a/c system .. it shouldn't flash like that .
off hand i would be thinking a flap motor or indeed a broken flap shaft .
Indy Mechanic .
LouSlips
PostPosted: Mon Jul 15, 2019 8:20 pm    Post subject: Reply with quote
Thanks for the advice - will take it to my local Porsche garage - thought there maybe a specific fault relating to the flashing display - flashes 9 x only on start up.
