991 : 2011- 19
993 : 1993-1998 7
Cayenne : 2003- 4
CB-997.2
PostPosted: Sat Jul 13, 2019 8:42 am    Post subject: 997.2 slow starting and misfire Reply with quote
Hello 991uk, first time post here - I'm looking for some diagnostic help...
I have a 2010 997.2 Carerra s - lucky me Very Happy
Recently the car has been struggling to start. I have owned it 2.5 years and it has always fired within a second of starter motor cranking. Now it seems to be more like 4 or 5 seconds.
Last weekend when starting the car, it struggled (as above) then misfired for a few seconds before stalling. I tried again and with light throttle encouragement, it fired and ran normally. I haven't had misfires since but the slow starting persists. Once the car is warm, I can turn it off and it fires again perfectly without the delay.
My local indy has suggested the High Pressure Fuel Pump and internet research suggests the same for my symptoms. However, most of the stories on the internet relate to a recall in 2011 and I've found very few tales of failure more recently. I called Porsche Reading earlier this week and they confirmed that the recall was completed on my car in July 2011.
So my questions are;
- Does High Pressure Fuel Pump sound likely as the cause? A chap on pistonheads has made me nervous with a story of his OPC chasing a similar fault which turned out to be the ECU and resulted in a few thousand in bills (under warranty thankfully for him!)
- Do HPFPs have a tendency to fail even after recall replacement?
- Would a fault code reader help with diagnostics? I don't currently have one but have been meaning to buy one anyway.
My car is out of OPC warranty and I have used my local indy for everything so I do not have any relationship with an OPC. If I had I might be pushing them for some kind of good will - if it is the HPFP, it will have only lasted about 30K since recall replacement. That's pretty poor.
Grateful for any wisdom 911uk folks can provide to help with diagnostics.
Thanks,
CB-997.2
Smile
darkhorse
PostPosted: Sat Jul 13, 2019 11:48 am    Post subject: Reply with quote
Having tried some generic fault code readers on my car the codes were not very useful at all. You need to get the proper P codes and I bought Durametric for that reason, it is superb. It was £350 but paid for itself the first time I used it pretty much. You can also sell it and reclaim a good part of the purchase price as they are well sought after
I would suggest reading the fault codes is the first thing to do to be honest Thumb Could eliminate a lot of gueswork
PostPosted: Mon Jul 15, 2019 7:23 pm    Post subject: Reply with quote
High pressure pump if faulty will give fault codes .
With a tester you look at the actual values as well .
it should read approx 45 bar at idle .. i've seen anything from 5 bar to 200 bar with a faulty unit .
There was a recall .. but that doesn't stop a unit from failing .. either way you will have a fault code if this item fails .
Sorry for the delay in answering .. not been well recently so i haven't logged on .
Tel Boy
PostPosted: Tue Jul 16, 2019 12:23 pm    Post subject: Reply with quote
Hi CB,
I had a failure on my High Pressure fuel pump. Noticed that oil was dripping from it and it was found to be faulty and replaced.
I checked with OPC who said no recalls were due on my car (2009 997.2) but I didn't have any documentation to say it had been replaced or not. Got a local indy to sort it in the end.
CB-997.2
PostPosted: Tue Jul 16, 2019 5:53 pm    Post subject: Reply with quote
Thanks for the replies and advice folks.
I can gather from what has been posted that the High Pressure Fuel Pump is indeed a known problem on the 997.2!
Ref the diagnostic codes, am I right in assuming a bogo standard OBD reader won't capture the necessary data and that I will need a proper (read Expensive) tool which can read Porsche specific codes?
In terms of repairs, I have spoken to Porsche Reading again and my local indy and received repair quotes which are not far apart cost wise.
I put it to the Porsche Service chap on the phone that my HPFP has only lasted 35K ish since recall replacement and that didn't exactly represent good engineering! He told me that Porsche have a process where I can submit a goodwill claim if I feel something is substandard and Porsche will review my case. This process is still valid for my car (all cars I believe) which is now 9 years old and outside of OPC warranty.
The car needs to be diagnosed by an OPC (for £220 ish) then I can submit a claim which they will review and will offer all, some or none of the cost.
The million dollar question is whether my case represents poor enough engineering to get them to cough up - I have my doubts and do recognise that the recall was 8 years ago. However, given the similar cost between OPC and Indy, I think I'll give it a whirl.
**Note, I don't want this thread to drift into a debate on whether I should or shouldn't qualify for a goodwill payment!
Regardless of the outcome I think Porsche should be applauded for even having this process. I've never heard of anything like it before - do other marques have similar?
I will report back in due course....
PostPosted: Tue Jul 16, 2019 6:54 pm    Post subject: Reply with quote
First off the car needs diagnosing .. if it is a pump then there will be fault codes which imho a basic tester would show a code .. you may well get unknown code but there should be some numbers which we can check on .
There has always been Porsche goodwill .. the trouble is you have to ASK the service advisor for it .. he will then put in a ticket to Porsche .. they will make a decision and make an offer that's non negotiable .
They .. The service advisors don't as a rule tend to offer it regardless ... that's how Porsche wants it .
The amount offered though .. hmm .. an Indy will fault find , change the component and charge you .. it will be a lot cheaper than an OPC .
OPC may come back to you and say .. 30 % parts and labour .. which may well still be more expensive than an Indy .. hard call there and that's your choice .
It's also based on how much you use an OPC for work .. if never then its a lower amount than someone that tends to use OPC .. not really fair but that's how it used to work when i was at one ... it's about customer retention .. sigh .
Just imho of course and i know nothing really Very Happy
Obviously i push Indys these days as that's where i work but i also have no problems with OPC when they do the job correctly Smile
Magic919
PostPosted: Tue Jul 16, 2019 6:56 pm    Post subject: Reply with quote
Hopefully they’ll chip a bit off for you. Worth asking. I’ve only ever needed it on a Porsche, so can’t speak about other makes.
997.2 C4S PDK
CB-997.2
PostPosted: Wed Jul 24, 2019 7:47 pm    Post subject: Reply with quote
Evening folks - I have some updates...
Firstly, thanks again for the input - particularly deMort - I'm new to these halls but the more I read, the more I see how much help you provide. Bravo sir!
I have used a basic OBDII reader which has given me a DTC P1023 code. A bit of internet research suggests it is (as expected) fuel pressure related.
I've also noticed there is some residue under the left rear of the car. Not on the floor but on the car. It is odourless but black and oily. The attached pic shows the location...
I plan to get the car booked in somewhere ASAP. I have preferred indy garages for my Porsche and aging BMW M cars previously and always found them better value. However, with this issue I have called two indys and one OPC and the indys are quoting higher for the HPFP. The difference is in labour. Indys are allowing 3-5hrs labour where the OPC has quoted 1.5hrs. When I questioned the OPC on this they said it was realistic.
Are the indys over egging it, or is the OPC under quoting?!?
CB.
CB-997.2
PostPosted: Wed Jul 24, 2019 7:48 pm    Post subject: Reply with quote
The pic...
 Filesize:  1.64 MB
 Viewed:  2322 Time(s)
PostPosted: Wed Jul 24, 2019 7:58 pm    Post subject: Reply with quote
Bless you .. the pump replacement is circa 2 hrs .. 1.5 - 3 is what i would expect to be quoted as a customer .
An indy would spend a bit more time making sure that was the only fault and resetting adaptations hence 2 hrs is a fair charge .. above that .. hmm .. not for me to comment .
There is also the matter of diagnosis .. a 1 hr charge is pretty standard to diagnose a fault .
CB-997.2
PostPosted: Wed Jul 24, 2019 8:17 pm    Post subject: Reply with quote
Good to know - thanks.
Can you comment on the picture I posted with the leak? To my ignorant eye it is just another lump of machinery in a very busy engine bay!
Cheers.
Tel Boy
PostPosted: Thu Jul 25, 2019 12:59 pm    Post subject: Reply with quote
Your pic looks exactly what happened to mine. Started dripping very small amounts of oil when hot. Mine is fine since HP Fuel pump was replaced.
PostPosted: Thu Jul 25, 2019 6:05 pm    Post subject: Reply with quote
Cheers.
Sorry young man .. yes that's the high pressure pump in the top part of the circle .. it has a protective ally cage around it .
They don't normally leak but its possible .
It will be obvious whats leaking when its worked on .
The usual fault on these was the quantity control valve .. too much or too little pressure .
 Filesize:  149.06 KB
 Viewed:  2168 Time(s)
CB-997.2
PostPosted: Wed Sep 04, 2019 7:41 pm    Post subject: Reply with quote
An update to close this one off... (apologies for being slow)
My local OPC estimate was pretty much the same cost as my local indy. The OPC also suggested there may be some goodwill because the car had previously had a High Pressure Fuel Pump replaced on recall. Whilst I would normally use an indy, based on this I had nothing to lose by going OPC (or so I thought).
The OPC took the car in, completed their own diag to confirm it was the HPFP, then took a week to confirm that no goodwill was available. To be honest I didn't expect any goodwill and don't have an issue with this (other than it taking a week). The OPC then told me that the estimate they'd given previously (which was still visible on their system) was wrong, the person who provided it didn't work there anymore and the part numbers quoted did not exist on the Porsche system. The real cost was 50% more than quoted. Ouch.
I was really unimpressed with this. Won't moan for ages on here about it because I've had a chance to calm down but the car was only with them based on the estimate provided with the slight chance of goodwill. I understand costs can change if additional faults are found but that wasn't the case.
To cut a long story short, I complained and got a little discount - perhaps I should be pleased I didn't pay full OPC rates.
Anyway, the fuel pump was replaced and the car is running well. I enjoyed a long drive over the weekend on some great roads. Other than a bit of a kick in the wallet, all is well. Back to indys from now on.
Thanks again to those who helped with the original diagnosis.
Maccy
PostPosted: Thu Sep 05, 2019 8:48 am    Post subject: Reply with quote
Interesting, I have a very similar problem with mine at the mo but will be going back to the dealer to get resolved.
Some people have suggested checking the MAF sensor first though, and you can unplug it and see if it starts ok.
Silver 997.2 GTS Cab
PostPosted: Thu Sep 05, 2019 6:53 pm    Post subject: Reply with quote
@ CB-997.2
I got a bit annoyed at just reading this .. i can well understand how you must have felt .. just not acceptable these days .. OPC do at times seem to have totally lost the plot on customer service ..
yeah we were wrong so we are gonna charge you more .. sigh .
@ Maccy
Any fault codes or other info ref driving it ? a High pressure pump makes the car alost undrivable .. also sounds like a garage has looked at it before ?
If it hasn't been into a garage and it will be then please don't unplug anything .. it will generate fault codes which the garage may interpret as the fault ..
You'll end up paying for a part they replace that may well not be the actual fault .
Maccy
PostPosted: Fri Sep 06, 2019 8:26 am    Post subject: Reply with quote
deMort wrote:
@ Maccy
Thanks mate, it's still under warranty and booked in next Thursday, they've got it for 3 weeks whilst I'm holidaying in the USA Smile
PostPosted: Fri Sep 06, 2019 7:30 pm    Post subject: Reply with quote
If they cant fix it in 3 weeks then you seriously need to bring it to me Floor
Have a nice holiday and i'm sure it will be fixed on your return Smile
Maccy
PostPosted: Mon Sep 09, 2019 7:13 am    Post subject: Reply with quote
Aye any excuse to come down to the south coast!
PostPosted: Mon Sep 09, 2019 6:30 pm    Post subject: Reply with quote
Always welcome but i'm afraid we can't offer Porsche warranty lol .
Keep me informed though please .. i like to keep up with faults and what recifies them .
