991 : 2011- 19
997 : 2004- 76
996 : 1997-2005 35
993 : 1993-1998 7
Cayenne : 2003- 4
Jamesx19
PostPosted: Thu Jul 11, 2019 2:33 pm    Post subject: Mot emissions fail Reply with quote
Too lean. Not sure which side probe went in, or whether tester tried both.
Engine passed in this spec last year after rebuild etc.
Thoughts?
Mot tester queries whether it may be an air leak in exhaust, which is newish (before last year's Mot) stainless manifolds and 200 cell cars. And knackard re-welded several times PSE rear boxes...........
Car runs lovely, idles fine. No fault codes.......
Cheers James
1998 C2 Manual + The Full Hartech.
PostPosted: Thu Jul 11, 2019 2:41 pm    Post subject: Reply with quote
Can't see it being a leak in the exhaust as the fumes leak out, not suck air in.
Was at tickover or at higher revs that it failed on?
BHZ661
PostPosted: Thu Jul 11, 2019 3:29 pm    Post subject: Reply with quote
Ive struggled for several years with emissions , ive changed most things and still no better , but always seem to scrape thro in the end Smile
Jamesx19
PostPosted: Thu Jul 11, 2019 6:12 pm    Post subject: Reply with quote
Hi Alex,
Hmmm, yeah thought the same. The sheet seems to indicate the speed between 800 and 1500. So idle as opposed to 2000 rpm.
No running issues at hot or cold that I can detect from driver's seat. Lambda sensors probably quite elderly. All manifold and Cat bolts tight. Some very small blows from various bits around boxes and pipe join to the Cat pipe.
May have to actually take it to a Porsche indy!!! Not done that for a couple of years..... Surprised
Cheers BHZ661 - that's what I want to avoid if at all possible.
I'll pull a spark plug or two and see what they look like may be.
PostPosted: Thu Jul 11, 2019 6:16 pm    Post subject: Reply with quote
If its around tickover I'd suggest maybe your MAF is giving an incorrect reading.
PostPosted: Thu Jul 11, 2019 7:10 pm    Post subject: Reply with quote
Maf should read approx 16 kg/hr .. with a voltage of 1 volt engine not running .. approx 1.27 volts running ... over 1.1 volts ignition on and the maf needs replacing .
200 cells and you need to get them stinking hot to get a pass .. it might be just that .
Not sure if you have post cat sensors but i'm afraid that yes a crack or a leak will allow air to enter the exhaust and cause an incorrect reading .. normally on post cat lambdas and its a cause of an eml light on .. not always obvious shall we say .
You also have a possible inlet manifold air leak .. faulty lambda sensors .. i could go on ..
It's a case of looking for fault codes or looking at actual values for the different sensors and trying to figure it out .
Im afraid im not allowed to borrow a tester other wise i would have Sad
EDIT ..
Just to point out an eml light on is normally to do with save the planet stuff and not an actual running fault .
Common to have an eml light on and no obvious running problems .. manufactures are more concerned with saving the planet than the car .. that's current legislation though so they have no choice .
Im certainly not going to argue that this is a bad thing though .. just pointing out a how it works Smile
Jamesx19
PostPosted: Thu Jul 11, 2019 8:17 pm    Post subject: Reply with quote
Uh oh! Could be in for a long haul then! Will test MAF first.
To summarise:
Engine off, ignition on. Should be 1 volt. Anything over 1.1 and it's shot.
Engine on. 1.27 volts should be seen.
Which pins of the four should I be looking at Iain?
By the scrapes on the tailpipes. Probe has been up both pipes, which indicates an overall problem rather than a leak in the exhaust I feel, but then if both silencers are toast, maybe not.
Only have pre cat lambda's. Looked for codes, none displayed.
Jamesx19
PostPosted: Thu Jul 11, 2019 8:36 pm    Post subject: Reply with quote
Just realised that doesn't work as I can't get to the pins with the connector connected to feed it!
Cleaned it with tihnners.
If the engine runs and idles, if I disconnect the MAF, should the engine change speed etc if it's working?
If nothing changes can I safety assume it's not working?
kurlykris
PostPosted: Thu Jul 11, 2019 8:40 pm    Post subject: Reply with quote
Pin 5, you may be able to get a paperclip or suchlike onto the connection with it still plugged in, that`s what I normally do at work Thumb
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
