997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
Kbald
PostPosted: Sat Jul 06, 2019 6:35 pm    Post subject: Muffler bypass done Reply with quote
Well I spent the afternoon fitting new exhaust pipes removing the mufflers as I found the stock exhaust a bit tame.
I will be spending tomorrow taking them off again! I'd watched some YouTube videos and the bypass sounded nice and not too loud but in real life it's very very loud. TVR loud. Too loud for me.
I think I will be looking for a stainless backbox to give me a bit more noise but not to the bypass level. Would like some new manifolds but the bolts on the original look like they would shear off or the heads would round so as no leaks will leave well alone for now.
2000 Carrera C4 Cabrio Tiptronic
Kingb4
PostPosted: Sun Jul 07, 2019 5:37 pm    Post subject: Reply with quote
Interesting to read this....I did look at complete bypasses (L-shaped pipe that completely removes any mufflers from the system) - but read that people felt they were too much.
I have just fitted Designtek supremacy back-boxes (that are a muffler, with a pre-made gundo hack (the small bypass pipe)). Seems to be a good compromise, they are sensible volume, unless you drive it hard.
2002 996.2 C2 Cabriolet
Kbald
PostPosted: Tue Jul 16, 2019 8:49 pm    Post subject: Reply with quote
Thanks for the info will have a look at that back box style. The ones I fitted were the l shaped ones. Will stick them on eBay as someone will be happy with the volume.
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Tue Jul 16, 2019 9:24 pm    Post subject: Reply with quote
I did the 2.5 ID pipe on my 3.6 boxes years ago and I think its perfectly civilised and has a great sophisticated sound to it when on it and not too loud at all when just cruising along.
What size pipe did you use, I assume on 3.4 boxes between the two external pipes?
Marky911
PostPosted: Wed Jul 17, 2019 5:12 am    Post subject: Reply with quote
Oh well, at least you had a go. You wouldn’t have been satisfied until you’d tried them.
Aren’t they god awful bloody things though. Grin
I can’t help commenting on every thread I see about them. They turn the car into a Chav-wagon instantly and people (well, me) just think “*****” as you drive past and deafen them. Very Happy
Wise move going for sports boxes. It will retain that flat 6 sound that gets lost with those delete pipes. Thumb
Kbald
PostPosted: Wed Jul 17, 2019 5:23 pm    Post subject: Reply with quote
infrasilver I'm not sure of the exact size but they fitted over the pipe from the cat so marginally bigger maybe 3.5 inch.
Marky911 you're right I felt very self conscious as I passed pedestrians and the sound wasn't anywhere as sweet as I'd hoped for. A nice sportbox would be a nice compromise as the stock mufflers are a bit tame sounding imho.
Drew1209
PostPosted: Wed Jul 17, 2019 7:27 pm    Post subject: Reply with quote
I think these are hard cars to get sounding right, I’ve tried a few box variations now along with the 200cell top gear cats and still I’ve not got the sound I’m looking for, currently back on my standard boxes with the sport cats.
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Wed Jul 17, 2019 9:50 pm    Post subject: Reply with quote
It all depends where you put the bypass pipe, I am assuming you have just done the bypass mod and not deleted the "muffler" all together. I think the factory PSE system used a 3" bypass pipe and this is pretty much as good as it gets for sound, I went a bit tamer and used a 2.5" pipe which sounds spot on for me but does make a great sound at the top or the rev range but with it being the 3.6 engine the bypass mod it done from the top of the silencer to the pipe in the middle, the 3.4 usually uses a much thinner pipe, I think around 1.5" - 2" and goes between the middle pipe and the one at the bottom. The above sizes get the same sound from the different silencers so going too wide a diameter can make a huge difference to the sound and can be unobtrusively loud if too big.
Kbald
PostPosted: Thu Jul 18, 2019 6:43 am    Post subject: Reply with quote
Hi infrasilver the mufflers were gone altogether so the tips were attached straight onto the cat pipes and out of the back. The pipes used were the same as in the picture. Saves quite a bit of weight not having the stock muffler boxes but gets too loud for me.
 Filesize:  6.73 KB
 Viewed:  1194 Time(s)
TurboRob
PostPosted: Thu Jul 18, 2019 7:17 am    Post subject: Reply with quote
Racecar loud!
996.2 C2
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Thu Jul 18, 2019 1:05 pm    Post subject: Reply with quote
I have never heard of anyone doing this and actually liking it afterwards.
kingston
PostPosted: Thu Jul 18, 2019 4:31 pm    Post subject: Reply with quote
Ive had straight pipes from cat back on mine, though the pipework followed the original route as opposed to the above.
Loved it (so did everyone else except one neighbour and they could ***** right off) but hated that it robbed it of noticeable low down torque so switched out to something else. If it wasnt for the torque issue, id have kept them on the car
I really must learn to spell check and proof read my posts Smile
