997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
FZP
Estoril
PostPosted: Fri Jul 05, 2019 6:55 pm    Post subject: Drivers Window issue. Reply with quote
I've tried the search, but I'm not sure what it's called.
The issue is when I open the door the window would drop, and once you close the door it would then go up again. The issue is now when I open the door, it drops and then a second later it goes back up again. To close the door i need to hold the handle in the open position until the door closes and then I can release the handle, allowing the window to do what it would normally do.
How do I reset it so it works normally again?
PostPosted: Fri Jul 05, 2019 8:05 pm    Post subject: Reply with quote
fault code read out of the drivers door control unit then i expect it will be a problem with the door lock ass... it sees the lock as shut but the handle overrides it until released .
This sort of thing is diagnosed with a tester im afraid .. we can see the actual values of the micro switches and say which one is not correct .
FZP
Estoril
PostPosted: Sat Jul 06, 2019 3:14 pm    Post subject: Reply with quote
Thanks Iain
I'll get a tester on it
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sat Jul 06, 2019 3:21 pm    Post subject: Reply with quote
Mine did the same this year for a while, in the end I just bought an Audi TT door latch assembly which cured the problem, its exactly the same but cheaper.
FZP
Estoril
PostPosted: Sat Jul 06, 2019 3:23 pm    Post subject: Reply with quote
Cost reduction back....I'm all about that Thumb
Thanks for the heads up
easternjets
Watkins Glen
PostPosted: Sat Jul 06, 2019 3:55 pm    Post subject: Reply with quote
It must be something in the air as mines been playing up as well.
Window goes up to about 3/4 then stops and goes back down again as if somethings stopped it. Then if you push the switch up and hold it, it goes all the way up.
Don't want to have a Phil situation where it's stuck down in the rain and snow and you've got to drive across 2 countries, not funny nooo
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
PostPosted: Sat Jul 06, 2019 4:20 pm    Post subject: Reply with quote
That is unfortunately the roll back function kicking in when its not supposed to .
In theory it can be down to a tight runner .. in reality it's a new window motor / control unit .. all the same part .
997 fault only .
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Sat Jul 06, 2019 4:23 pm    Post subject: Reply with quote
I could actually be wrong as I think the part is different on the 997
