997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
Divad968
PostPosted: Fri Jul 05, 2019 2:30 am    Post subject: Porsche PIWIS 2 Rear-end Electronics Coding for Cayenne Reply with quote
Preparations:
Porsche Piwis2 V18.15 V17.500 Free Download
How to Install/Restore Porsche PIWIS 18.100 Universal Image
Procedures:
1.Click [DIAGNOSTICS]->[Cayenne]->[92A from MY 2011]
System initialing
2.Select [Rear-end electronics] then Click [Next] or press F12 to continue.
3.Press F11 to continue Create a VAL? Yes with [F12], no with [F11]
Control unit overview
Control unit search has been completed.Select control(s) and select the required function via the menu.
4.Click [Codings adaptations]
5.Select [Automatic coding] then click [Next] or press F12 to continue.
Control unit coding
Coding in progress.Pleasse wait…
6.Coding has been completed successfully.Click [Next] or press F12 to continue
PostPosted: Fri Jul 05, 2019 7:26 pm    Post subject: Reply with quote
Wrong forum .. needs to be in the cayenne section Smile
You only need to do this after a campaign or if the control unit has been replaced .. a campaign and you often need to auto code every control unit .
Auto code is there as each control unit does not have its own coding option anymore .. it takes the info from a list of specs for the car ( maintenance of vehicle date ) .. prior to this you could code each control unit individually .
can a mod move to the required section please as its of use there .
Indy Mechanic .
