997 : 2004- 69
996 : 1997-2005 35
Boxster : 1997- 22
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Thu Jul 04, 2019 11:30 am    Post subject: Gen 2 non-PASM front springs question Reply with quote
I have a feeling I have cracked one of my front springs as I’m getting a clunk noise when on full lock (but not when car is on the jack).
What is the OE part for my non-PASM carrera? Who makes it and where is best source?
The search function just brings up threads discussing lowering, which I’m not fussed about.
I know bilstein do the dampers but can’t find anything on their site for springs Confused
Thanks in advance
wjk_glynn
PostPosted: Thu Jul 04, 2019 5:01 pm    Post subject: Reply with quote
You can download the parts catalog for your car from Porsche.
https://www.porsche.com/uk/accessoriesandservice/porscheservice/serviceandorgininalparts/originalparts/
Scroll down a bit and you can select which catalog to get.
It has diagrams and part numbers galore.
Karl.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Brake Airflow (996 GT2 front scoops, 997 Turbo rear scoops, 997 GT3RS rear L-ducts) • 3rd (center) Coolant Radiator • TG Muffler Bypass
PostPosted: Thu Jul 04, 2019 6:50 pm    Post subject: Reply with quote
Put the wheels on a full lock , jacked up if possible .. feel along the base of the coil spring .. if its a flat end and up against the shock ridge then its not broken.
you are looking for a jagged edge to the bottom of the spring and it not reaching the ridge on the shock for it to be broken .
Do this both sides please before ordering new springs .. always best to diagnose first Smile
PostPosted: Thu Jul 04, 2019 6:52 pm    Post subject: Reply with quote
Karl.
Well stuff me !!!
you learn something new every day on these forums .. Thumb
Gray79
PostPosted: Thu Jul 04, 2019 8:39 pm    Post subject: Reply with quote
Karl.
That’s a great link, it will come in very useful thumbsup
997.1 Carrera 2S
James M-S
PostPosted: Thu Jul 04, 2019 9:01 pm    Post subject: Reply with quote
Thanks gents,
DeMort, would the bottom of the spring still feel rough even if the break is in the middle?
I found the part number (according to porscheshop), 997.343.531.40.504 front springs non-PASM for all 997 c2 & c2S coupe for future ref.
£210 from porscheshop
EDIT the above number doesn’t match those given in the parts catalogue above (p172)
It really is a great link - thanks again thumbsup
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Thu Jul 04, 2019 9:31 pm    Post subject: Reply with quote
You have to remove the dots and replace with spaces as that’s how the numbers are formatted in the parts catalogue pdfs, so 997.343.531.40.504 becomes 997 343 531 40 504
James M-S
PostPosted: Thu Jul 04, 2019 9:59 pm    Post subject: Reply with quote
Thanks, I had realised that, but the digits are different.
I need to go and check the coloured dots on the springs to make sure I get the correct ones, as there are several listed for the coupe. (different spring rates I guess)
wjk_glynn
PostPosted: Thu Jul 04, 2019 10:14 pm    Post subject: Reply with quote
Hiya,
Since you have a standard 997.2 Carrera, you would have downloaded the 2009-2012 version of the 997 UK catalog.
On p173, the p/n listed for a front set of springs on a I029 C2 Coupe is "997 343 531 46 504"
I say I029 because if you look up the V-Pages section, you'll see that 'I029' is the standard chassis (p19), which is what I believe you have.
Here's an example of a vendor with that p/n (I live in the US):
https://www.sunsetporscheparts.com/oem-parts/porsche-coil-spring-99734353146504/
According to Sunset Porsche, that part is for the 997.1 generation cars.
https://www.sunsetporscheparts.com/oem-parts/porsche-coil-spring-99734353140504
Just make 100% sure you downloaded the right version of the 997 UK catalog (2009-2012), and not the one for the earlier generation cars (2005-2008).
Karl.
Hertsdriver
PostPosted: Fri Jul 05, 2019 9:09 am    Post subject: Reply with quote
As per the answer above I think you typed a '0' where it should have bene a '6':
D911 have them:
https://www.design911.co.uk/parts/99734353146504/coil-spring-1-p-------------00
for the cost of 2 new springs (you probably dont want to change just one...) you might as well get an Eibach kit and get rid of the nasty arch gap.... Wink
James M-S
PostPosted: Fri Jul 05, 2019 9:11 am    Post subject: Reply with quote
Thanks Karl Cheers
There are several listed for I029, with different colour ratings, which I assume is spring stiffness (could be length I suppose).
There are coloured dots on the springs themselves, which correspond. Mine are red red green.
PostPosted: Fri Jul 05, 2019 7:18 pm    Post subject: Reply with quote
James M-S wrote:
Thanks gents,
When you jack up a car with a broken spring or indeed put it on a ramp then the broken part often falls out ..
the broken part will have a sharp edge on it and not reach the stop .. it feels wrong basically and too short ..
All i can say is jack it up and run your fingers around the base of the coil spring .
this is one of those things thats far easier to show you than to explain .. sigh .
You may well have this issue .. but as usual im concerned it might be something else so always prefer proving something first rather than just ordering parts .
James M-S
PostPosted: Fri Jul 05, 2019 10:42 pm    Post subject: Reply with quote
Thanks, I agree with proving it before spending. (Certainly for a £200 part).
I’ll be checking tomorrow.
