991 : 2011- 19
997 : 2004- 77
996 : 1997-2005 35
993 : 1993-1998 7
Cayenne : 2003- 4
Cannop
PostPosted: Tue Jul 02, 2019 1:28 pm    Post subject: Gearbox switching module oil weep Reply with quote
The MOT on my 997.1 manual picked up a weep from the switching module at the point where the lever pivot goes through the actual module. The weep is very slow and it doesn't actually drip on my drive but is has stained the undertray.
I've been told by my indie that the pivot sits high in the gearbox and is above the level of the oil, so any loss is through oil splashing about inside when in use.
The module itself is part number 99730393000, labelled No2 in the diagram below.
I'm assuming there must be an o-ring or seal in the bush housing and I'm assuming the lever itself must be riveted in place hence it's only available as one part.
I'm wondering if anyone here has disassembled one of these to sort out a weep? As this part is near enough £600 it would be good if there is a way of stripping and sealing it.
If there's no way of doing so I'll replace the whole unit in due course, but if it is possible to effect a permanent repair then all the better.
Full fat Hartech'd C2S Manual
