991 : 2011- 19
997 : 2004- 76
996 : 1997-2005 35
993 : 1993-1998 7
Cayenne : 2003- 4
Stu3004
PostPosted: Mon Jul 01, 2019 10:29 pm    Post subject: 997 air conditioning pipes Reply with quote
Evening.
My air con hasn't been working too well and following a re-gas attempt a leak has been found. It's the pipe that runs from the engine bay down behind the rear wheel (the thicker of the two). The leak doesn't seem accessible so a repair in situ isn't looking likely.
I have read a few posts on here and some suggest engine out job depending on the pipe - is that the case? Seems OTT for an aircon pipe but to be fair there ain't much room in that engine bay!
If so what would be the ball park for this £ wise, have already braced myself!
Otherwise so far so good with the car 3months in, will post an update shortly.
Stu.
glenwells
PostPosted: Tue Jul 02, 2019 5:47 am    Post subject: depends on the damage Reply with quote
Both my 911's had air con issues when I bought them it is a fairly common issue both had a front rad go/gone and the first had a rear leak as well.
Did you see the damage?
Is it a joint gone bad, corrosion, crush damage or a pin hole?
I ask because my first one had what looked like minor crush damage and a pinhole you could see the yellow fluid staining.
This was where the pipes ran under the car to the rear wheel arch and then up inside.
As a temporary fix I used the two part metal putty then wound some quality outdoors tape that I had in the shed around it.
Maybe it was because it was a pinhole in a small dent but it worked.
It was only a temp fix because the weather was hot and I had other things I needed to direct cash at at the time.
However, because it was working fine I forgot about it and a year later it was still holding and no sweating or yellow staining around the area.
Aircon worked fine and no obvious drop in performance.
Whilst I do not advocate such a bodge job as mine there are a number of fixes dependant on type of pipe damage and of course where you take it.
A garage my be able to make a piece and weld it in without engine drop or possibly repair a pinhole in situ.
An independent Porsche garage wanted to drop my first cars engine to replace a 'corroded brake pipe' that difficult to access for £800+. My other local garage had a look, said it wasn't that bad, cleaned the surface rust off is situ with a flexible attachment and a small piece of emery paper and then treated the pipe. I was a little concerned but said if it did not last 15 years they would change it for free! Cost was £30.
Above is just to illustrate there can be a work around.
Engine drop now is quite a bit more I think.
Hope you get it sorted and enjoy the car.
Regards
Glen
brownspeed
PostPosted: Tue Jul 02, 2019 6:23 am    Post subject: Reply with quote
Surprised
2004 997.1 C2S (Hartech rebuilt)
2002 TVR Tamora 3.6
1990 Mini Cooper RSP
Abarth 595
Supersport Mike
PostPosted: Tue Jul 02, 2019 5:54 pm    Post subject: Reply with quote
My a/c had a small pin hole in the pipe that runs along the side and is hidden by a block which the pipes sit in , so it was hidden ,water and corrosion gets in between the block and pipe …..***** to find but repairable
PostPosted: Tue Jul 02, 2019 7:24 pm    Post subject: Reply with quote
i'm pretty sure this is an engine out job to replace .. the pipe is a fixed shape and i don't believe there is enough room to manoeuvre it out .
let's put it this way .. i found instructions for every other a/c pipe replacement other than this one !
A/c pipes and they tend to corrode inside of the clamp brackets .. a small black spot when you dig at it is actually a pin prick hole .. a slow gas leak basically ...
A misting of oil and it's definitely a leak .
Dropping the engine by a few inches .. pipes connected will not work imho .. its an 8 hr job to drop and refit an engine .
Engine out and it soon descends into what else is worth changing whilst im at it .. these things do tend to spiral upwards .
Stu3004
PostPosted: Tue Jul 02, 2019 7:53 pm    Post subject: Reply with quote
The pipe is knackered (technical jargon) as it's in two pieces now so will start planning to schedule the full job and as you say demort it will spiral but may as well tick off a few known items (coolant pipes, rear oil seal(?) and any other bits that crop up).
Went in with eyes open these cars cost money but not as much as depreciation on something newer - classic man maths....
Just drive faster with the window open for now and go all Wimbledon with some sweat bands (no pics will be posted don't worry). Very Happy
Gray79
PostPosted: Tue Jul 02, 2019 8:21 pm    Post subject: Reply with quote
Thread Hijack
On a slightly different note, how much air con gas do they hold, and are they on r134a, as at some point I’m going to re-gas mine?
997.1 Carrera 2S
brownspeed
PostPosted: Wed Jul 03, 2019 6:50 am    Post subject: Reply with quote
mine has never worked; i assumed it was the condensers. I think i'll get it on a ramp and carry out a thorough look before I re-gas it
2002 TVR Tamora 3.6
Abarth 595
PostPosted: Wed Jul 03, 2019 6:37 pm    Post subject: Reply with quote
Gray79 wrote:
Thread Hijack
Try this site ..
https://www.hella.com/techworld/uk/Technical/Car-air-conditioning/Car-refrigerant-oil-filling-quantities-2114/
scroll down then enter the car details .
personally i would go with 900 over the 850 they list though .
Gray79
PostPosted: Wed Jul 03, 2019 7:22 pm    Post subject: Reply with quote
deMort wrote:
Gray79 wrote:
Thread Hijack
Try this site ..
Thanks thumbsup
Very useful list.
997.1 Carrera 2S
P9XX
PostPosted: Wed Jul 03, 2019 8:47 pm    Post subject: Reply with quote
I used this site for re-gas information after fitting new condensers last year.
https://www.pelicanparts.com/techarticles/Porsche-996-997-Carrera/97-ELEC-Air_Conditioning_Maintenance_and_Recharge/97-ELEC-Air_Conditioning_Maintenance_and_Recharge.htm
2008 997.2 C2S PDK Basalt Black
