997 : 2004- 63
Cayman : 2005- 22
Macan : 2014- 7
9xxnick
PostPosted: Mon Jul 01, 2019 11:30 am    Post subject: Oxygen / lambda sensor failure symptoms and lifespan Reply with quote
My car ('94 C2) has 110K miles on it now and has developed an intermittently hunting idle and slight loss of power.
The Bosch diagnostic tool is reporting that the Oxygen sensor is open circuit so I have a Bosch replacement on order.
I'm curious to know if it is fairly typical for these sensors to fail at this kind of mileage on 993s and whether anyone's had similar symptoms.
Equally, if anyone thinks I'm barking up the wrong tree that'd be good to know too.
ollster
PostPosted: Tue Jul 02, 2019 12:17 pm    Post subject: Reply with quote
mine failed in a similar way (at about 115k) and was much smoohter on part throttle when replaced with a new item
decgraham
PostPosted: Tue Jul 02, 2019 12:58 pm    Post subject: Reply with quote
In the Bosch lambda catalogue they say that they are good for 160000 Kms or around 100000 Miles.
If you have poor idle you might want to give the ISV (Idle Stabiliser Valve) a clean, Jackals write up below Thumb
http://www.jackals-forge.com/lotus/993/993_60k_isv.html
ATB Smile
Cameltoe & Heel
PostPosted: Tue Jul 02, 2019 1:23 pm    Post subject: Reply with quote
These are usually interesting to get off so let us know how you get on.
Trev
9xxnick
PostPosted: Tue Jul 02, 2019 4:17 pm    Post subject: Reply with quote
Thanks chaps. The ISV has been cleaned, as has the MAF sensor, so hopefully these are OK.
I'll let you know how I get on with the O2 sensor.
9xxnick
PostPosted: Wed Jul 03, 2019 5:33 pm    Post subject: Reply with quote
Well, the old sensor is moving freely on its thread after a light application of Kroil and a little bit of encouragement with a rubber mallet on the end of a 22mm spanner. New unit should arrive tomorrow, so hopefully we will have a result soon.
9xxnick
PostPosted: Sun Jul 07, 2019 7:56 pm    Post subject: Reply with quote
The new sensor's fitted and seems to be working perfectly. The idle is stable and performance seems to be restored.
Next job: work out why the allegedly standard new gearbox mount has created a lot of additional noise, vibration and harshness....
Gwsinc
PostPosted: Fri Sep 06, 2019 8:37 am    Post subject: Reply with quote
I replaced my O2 sensor last month at 25 years old and 58000 miles. It had a few bashes in it, I guess from its last engine out job.
Running even better now..
In response to the last comment about your gearbox mount, how are your engine mounts? Your newly firmed up gearbox mounts might be exposing old rubber/loss of fluid in the engine mounts? Just a thought!
kingroon
PostPosted: Fri Sep 06, 2019 9:11 am    Post subject: Reply with quote
Great result.. Thumb
Could you post a link to the new O2 sensor..? Will be good to keep in my "993" Browser Favourites for future reference..!
Hasta Luego..
KingRoon
1994 993 Carrera Coupe
9xxnick
PostPosted: Fri Sep 06, 2019 9:42 am    Post subject: Reply with quote
This is it: https://www.carparts4less.co.uk/p/bosch-lambda-sensor-710330045
They often have discount offers on, giving 20% or so off.
kingroon
PostPosted: Fri Sep 06, 2019 9:45 am    Post subject: Reply with quote
Fantastic..! Thanks Cool Even better with the code WEEKEND17 Thumb
Hasta Luego..
KingRoon
2019-09-06 10_44_08-My Basket - Car Parts 4 Less UK’s No.1 for Car Parts.jpg
 Filesize:  38.52 KB
 Viewed:  1192 Time(s)
cableguy
Watkins Glen
PostPosted: Fri Sep 06, 2019 10:02 am    Post subject: Reply with quote
Currently £79.37 (Bosch) at Eurocarparts with the WEEKEND37 code. Wink
C.
Pork!
9xxnick
PostPosted: Fri Sep 06, 2019 7:40 pm    Post subject: Reply with quote
Carparts4less and Eurocarparts are the same company. Carparts4less seem to be a little cheaper some of the time but always worth checking both.
