997 : 2004- 66
996 : 1997-2005 34
964 : 1989-1993 1
Cayman : 2005- 20
Cayenne : 2003- 7
Macan : 2014- 6
Luddite
PostPosted: Tue Jul 02, 2019 2:56 pm    Post subject: Reply with quote
DH, just wanted to echo the sentiments already expressed by others. I have spent many years rolling around the garage floor working on my cars, less so these days, and any time I had access to a lift I did not feel comfortable working while standing up or bending my neck looking up at the underside.... I guess it can be just what you get used too.. and I ever worked on my cars solo too.
Following your progress with great interest, appreciating the all the effort to post it here too.. Thumb
darkhorse
PostPosted: Tue Jul 02, 2019 3:24 pm    Post subject: Reply with quote
good stuff luddite! thanks Smile
I have worked from a lift in the past when one was available and to be honest I would prefer it but I dont have one lol so have to make do until I move house and get a huge man barn hopefully Grin
rabbitstew
PostPosted: Wed Jul 03, 2019 12:58 pm    Post subject: Reply with quote
Good work! Ive just stripped a new mini down and pretty much rebuilt it - new suspension, brakes, all the full major service stuff, plus supercharger service, new ignition, new coolant system etc. Took the gearbox off and did the clutch as well as about a million other bits on it, but for some reason I never work on my 997 turbo - so fair play to you.
With regards to ramps, i use quickjack ramp. Best thing i ever bought for my garage. You just slide them under the car, press a button and the cars up in the air by 3 foot and safer than axle stands.
When my car was at 9e they mentioned there are 2 types of water pump for the 997 turbo. One has metal blades and the other has plastic. They usually check when the engine is out and replace any metal bladed pumps with plastic, as if they fail they are less likely to cause any damage.
2008 997.1 Turbo Manual - 585whp thanks to do88 & 9e
darkhorse
PostPosted: Fri Jul 05, 2019 6:12 pm    Post subject: Reply with quote
thanks rabbitstew.
quickjack wouldnt work for engine removal I don't think looking at the lift it provides, but it looks excellent for most other jobs!
Good to know about the waterpumps as well, cheers
Not had much time this work to work on the engine this week at night but I have started stripping some of the parts off, and entered the rats nest of 'shall I replace that too' territory.
Here are a few pictures
The water pump wasnt leaking visually, but the gasket seems to have been in poor shape around the bottom outlet, the pump itself is very smooth indeed and the non metal impellar type. I was going to replace it if it was in any way suspect but I will just be replacing the gasket at this time, as a new one will be no different going on past new water pumps I have fitted to cars. So it will just be cleaning the mating surfaces and a new gasket.
I have had a nightmare trying to get some of the fittings out of the turbos so the lines are getting cut tomorrow when its daylight. I also had a battle with the turbo exaust gas sensors that screw in at the back of the turbo, I managed to get one to free up with a lot of heat and repeat tries, but decided I would just fit new ones. I then got the price from the OPC today for them and it was about £750
Surprised so I will be removing mine now Grin
A largely hidden pipe with the engine in, is showing a lot of corrosion on the joint between the rubber hose and the metal, seeing as how its a main oil return from oil cooler to engine casing on bank 1 I am replacing it. I don't see it as a failure risk at this time, but I don't like it.
I am also replacing the other main oil return that runs from the top side of bank one, along the water manifold on the front of the engine and up through the intake to the oil tank because that is corroded at the same joint and looks grotty.
The price about £550 ish plus vat for the pair
Next job is to finish removing the rear water manifold (had a job getting the rubber coolant pipes off the pipe stubs on it) and then sort the leaking sealing washer on bank 1 side.
The oil drain lines are stuck into the bottom of the manifold so I am going to take it off to try and remove them.
I will also be removing, erm, most of the top of the engine so I can get access to the alleged 'weak point' coolant elbows. Sharkwerks do a set of 3 for about £800 ish imported, but the OEM ones are about £15 each I believe and the current ones are not leaking so I will use new OEM ones.
Then at some point, the worst bit of the job, making up a massive parts list using the Porsche parts breakdown pdf! So very tedious.
I will update the thread after the weekend.
cheers
NickHappy
PostPosted: Sat Jul 06, 2019 5:56 am    Post subject: Reply with quote
Can you get it into the living room somehow and do your work in there?? Grin
You’re going to be in that garage for a good few hours....
Still watching with interest, great updates thanks DH
997 turbo Manual.
996 turbo Manual. ex.
darkhorse
PostPosted: Sat Jul 06, 2019 11:49 am    Post subject: Reply with quote
The garage is my living room Very Happy
Yes, a fair bit to do, but may as well make a proper job of it; and attend to everything while I am at it.
After several more hours working at them I have managed to get the exhaust gas temp sensors out without damaging them, very pleased about that becase I didnt want to replace fully working ones at £800 if I didn't have to.
Also doing the secondary cooler o-rings while I am at it. and the main one thats under the throttle body area
Next jobs, remove front coolant manifold, inlet manifolds, and prepare the manifold for regluing the coolant pipe stubs. Also stripping down to where I can replace the turbo lines.
hermes
PostPosted: Sat Jul 06, 2019 4:01 pm    Post subject: Reply with quote
Wow, good effort on the engine removal without fancy lifts etc, and thanks for writing it up.
I have a question for you as I’m also planning to replace the flex disc on my C4S prop shaft.
My plan is to disconnect the propshaft, lower it a bit, and then swap the disc without removing the propshaft completely.
Based on what you can see, does that sound feasible?
darkhorse
PostPosted: Sat Jul 06, 2019 5:25 pm    Post subject: Reply with quote
Totally feasible yes. Porsche dont sell the guibo seperate but Its made by febi bilstein and they are available on ebay for about £50 ish. Your plan will work, was a bit of a tussle to seperate the prop from the output shaft, i used a lever bar on a safe area and it frees up easily
hermes
PostPosted: Sun Jul 07, 2019 1:53 pm    Post subject: Reply with quote
Thanks, suppose I should get on with it then!
darkhorse
PostPosted: Fri Jul 12, 2019 2:12 pm    Post subject: Reply with quote
Got time to do a bit on the car the last few evenings. To summarise, the turbo pipework has been a real PAIN and is seized in the old turbos and wont come out. I have tried heat, persuasion, more heat, brute force etc and they dont seem to want to come out. The main issue I have found is that the pipes simply dont have the strength to get good leverage behind the fittings so it is very hard to exert enough force on them. So to that end I have cut a couple to get to the pipes behind them, and could free none of them on bank 2 side so I am cutting my losses and just replacing them all with new..
The parts list has grown a bit more.
I am also replacing both turbo drain tanks as I got a good deal on a pair so it made sense as the old ones have seen better days and then it will all be new.
Oil lines, the long one at the bottom front of the engine, I tried to undo one union where it attaches on bank one side to the cam housing area, but although the nut unwound it is seized to the actual oil pipe Floor so I am going to cut both ends of the pipe with a dremel and cutter near the nut, and of course renew that pipe as it was manky anyway.
Oil line arrowed in red in the image below
On to the next battle, the front water manifold. So firstly I removed the coolant manifold on the top of the engine, which gave access to the water pipes to the front main manifold. Then the fun started. Although there was no sign of any leaks from the coolant outlets or pipes (because they were on so damn tight..!) I wanted to be careful removing the pipes so as not to gash or damage the outlets from the manifold.
Engine carrier and exhaust bracket removed, hmmm.... cant see any more fittings, more checks, levered the manifold gently to see if there was any movement.... a little.
So after a good few hours battling I ended up removing the elbows from the casings (that should 'just' be attached to the manifold with the oring coupler (with protector sleeve) and then with some serious persuasion with a rubber hammer, I managed to eek one elbow off and then extract the water manifold with the other one still seemingly welded on!!
The pictures below tell the story, not necessarily in the correct order Im afraid.
Suffice to say, I got access to the guide bolt I am sorting and found the cause of the displaced rubber cover to one of the coolant elbows... The rubber protector sleeve seems to have been damaged on installation (could only see it when the manifold was coming out as it was hidden) is the only thing I can assume, unless a small leak and the ensuing buildup of gunk made it bulge and let further badness in.
Anyway, Im glad I caught that as on a factory new car they may be easy to get off, in fact you can probably change the elbows to the block with the engine in place (maybe...) but not a 1% chance could it be done on this one!
So, will be cleaning everything up next stage, prepping the coolant manifold and resealing the (perfectly rock solid) coolant outlets!! and adding parts to the parts buying list.
Next job is a pleasant one, removing inlet manifold and all the other non rusty parts at the top of the engine. I have nearly cracked the worst of the old bits (got to cut the bolt off one turbo support still then cut the pipes and remove the turbos.) and after a mega clean up it will be parts list time.
I may well end up removing the gearbox to replace the large oil pipe that comes down from the secondary oil cooler to the block, hopefully it will come out without me needing to do that. But I will wait until the new parts have arrived to do that as it is one less oil inlet to protect.
darkhorse
PostPosted: Fri Jul 12, 2019 2:27 pm    Post subject: Reply with quote
As a sidenote, I think next time (note, I am sure there WILL be a next time) the engine comes out for any meaningful work I am going to put it on one of my engine stands, probably the beefy one. It will mean removing the gearbox yes, but will save a load of messing about and the use of my custom Porsche OPC 'beech log' tools; which have been very handy for rotating the engine into various angles! (pack one side up one side down)
For an intial phase though where a fair bit of force is needed trying to free seized components it's nice to have gravity on my side. An engine stand would have been flapping about a bit at some stages.
darkhorse
PostPosted: Tue Jul 16, 2019 7:18 pm    Post subject: Reply with quote
Another update to the thread...
It's is now parts order time Mr. Green
I decided to take it down to this level, order the new parts and then do the oil cooler orings and coolant elbows under there when I have the new parts in, as it is less orifices to seal up Grin
I am currently in the process of making a list of all of the bits I need. I have done phase one clean on the engine and will be doing another clean tonight.
Turbos will come off when I have the new pipes as I want to replace them as I remove them so I can get the routing right without major messing about seeing as its a first time stripping this engine.
Heres a few pictures of progress
Everything looks good , apart from the coolant elbow leak shown in a previous post. Also, all of the oil lines that are fitted with the dual orings are very well 'in'. I have not tried getting them out yet properly, but after a first attempt I know they will be nasty.
So, tomorrow is parts order time, and start to clean and prep the parts to go back on. Like coolant manifolds etc, big clean and prep for new orings.
The parts list I am making covers every oring, seal and rubber pipe on the top of the engine... On top of that are all turbo lines, and various gaskets and bolts etc
brownspeed
PostPosted: Wed Jul 17, 2019 6:25 am    Post subject: Reply with quote
worship worship worship (wow)!
2004 997.1 C2S (Hartech rebuilt)
2002 TVR Tamora 3.6
1990 Mini Cooper RSP
Abarth 595
darkhorse
PostPosted: Fri Jul 26, 2019 3:00 pm    Post subject: Reply with quote
ok so a few updates, after putting together a parts list, it seemingly kept on growing as I needed to buy specialist greases , sealants and the like for the reassembly of a few bits.
So the parts arrived yesterday thumbsup thanks to my friendly local Porsche centre, but there have been a few issues. Some of which are worth noting for any other 997 turbo owners.
The main one being, the pipes that supply the turbos with coolant (flow and return) are currently unavailable from Porsche, on long term backorder due to a change of manufacturer, so the new pipes are not even due for testing until the last 1/4 2019 expected Nov/Dec, but a date for being in stock is totally unknown.
This is clearly an issue, and I am just thankful that I only cut one of the pipes, fortuitously the ONLY one that the OPC was able to supply!!
So I have a plan for this and a 911t tuner in America has kindly helped me out with his old pipes which means I may not have to battle to get my ones out of the turbos. (Im removing them all as a unit to see if I can get them out)
Anyway, heres what £2500 of parts from Porsche looked like when they landed and as soon as the new turbo pipes arrive I will be getting it back together. I have spent a lot of time cleaning all the parts and the engine, that will be in another post when its rebuild time.!
I was very impressed with the quality of the turbo scavenge pump (image one), as I am replacing every seal and oring that I can get to I just had to disassemble it to have a look, the special optipit grease it needs on reassembly is rather pricey though I found...
I decided to rebond the main coolant manifold pipes. Well, what a waste of time that was.... I have no doubt there are people who have had these pop out on 996s and it seems to be more USA on 997ts. I can confirm mine where totally rock god damn solid and it took a lot (hours) of effort to get them out undamaged. As a result, I wish I had not started that job PC but hey ho, I will be rebonding them as in the video I linked earlier with jbweld and then they will be rock solid again.
Its the sort of job there is no turning back form as once you have applied heat to try and free one up, you are committed.
The only one that came out easier was the smaller one above the water pump, the one prone to the issue I believe, but even that was by no means loose or with any sign of leakage.
[/url]
darkhorse
PostPosted: Thu Aug 29, 2019 11:18 pm    Post subject: Reply with quote
Small bump to this thread post holiday.. Back on getting it finished so will post up some more details as I progress and I haven't forgotten about doing a removal refit guide. Will attend to that once I have it back together.
There has not been a great deal of progress due to holidays this month but I decided to replace some other parts so made a list of some random items (speed sensor brackets and other random bits that were rusty) , bought a new OEM water pump which I am waiting on. Also trying to find a cheaper source than Porsche for the 5 and 1 Coil packs. Anyone got any suggestions? the same with spark plugs; what are people using on their 997T?
The turbo scavenge pump that is located in the rear water 'bracket' or manifold as I refer to it proved to be a bit testy. Not much info out there on rebuilding it
Managed to get the WM info on it but it was a bit sparse on backlash and such. Now, had I known then I probably wouldn't have stripped it as I had to pay a silly sum for some special optipit grease from Porsche and then stripped and reassembled it 100 times to check it was turning perfectly because any issues would be bad in many ways (think damaged IMS or broken gears and metal bits or turbos with blown oil seals or all three!).
So now all the coolant pipes have been rebonded (as mentioned the only one that came out without a major fight was the small one under the water pump, that was a definite candidate for popping out as it came out in about 5 seconds. The others though.... no fun at all.
I digress anyway; will post some more useful updates next week, I have to replace the seal on the auto tranny connector as it looks like it may have leaked over time. Not going to remove the box in this sitting as at the moment its a known good element, and I dont need to remove it currently.
More updates coming soon.
I am also going to replace the orings in the cam oil scavenge pumps as I was advised to do this by a US builder of some repute.
The jury is out on whether I will buy a set of cam timing plates (cant rent/loan any for love nor money Sad ) to have in stock!
darkhorse
PostPosted: Mon Sep 09, 2019 2:14 pm    Post subject: Reply with quote
Not sure if this is talking to myself Question but an update to the rebuild works. Managed to get some time on this over the last few weeks and have reached the crux point; and am now on re assembly.
Summary of work done is - a sh*t load Mr. Green
but including replace camchain guide bolt washer
stripdown to the level as in the pictures below
Replace all orings, sealing washers, rubber pipes and coolant elbows.
Replaced both main oil pipes (the big return that enters the bank1 side of the casing) and the multipoint one that goes to the oil tank (Have to remove the engine bracket again to do turbo lines to front manifold so will attach the loose clip then! **for those who noticed it undone**)
Fit new tiptronic gearbox connector seal (I actually bought a new multiplug off ebay for the mercedes auto tranny but it was slightly different but was from the correct gearbox (the locking tabs were different) so I just used the orings off it.
Remove and rebond (not pin) the coolant pipe stubs (more to come on this *see pics)
Replace coils and spark plugs (on the pending list)
Fit new turbos and all turbo lines (coming soon)
Rebuilt front coolant manifold, new water pump, check and rebuild scavenge pump
Fitted new aux belt tensioner wheels
To fit driveshaft guibo
Remove any rusty bits, clean or replace
Plenty more I forgot
So, not wanting to waffle, here are some pictures, the order may be a little jumbled, apologies for that.
How it is now
and more repair pics
Hmm, doesnt look good
here you can see the fitting extruding , the brown stuff is the bonding epoxy that is left on the stub where it has pushed out.
I was semi pleased to find the coolant elbows off the main distributor were in good condition, no signs of leak and still with fresh looking silicone grease around them; I suspect they were replaced by OPC at some point, the engine has certainly been out before as the engine bay metal coolant pipes are new looking.
However I found on the bank one side that the rubber pipe that comes off one of the elbows was perforated BEFORE the jubilee, it seems He-man did the jubilee up way tooo tight and squint as well, and it has either torn then or more likely over time. There was also some coolant puddles on this side of the casings once I got it down this far, whether that was from stripdown or from previously I dont know. Either way, it was a problem and could fast have become a BIG problem!
The other thing I found is that the manfold that houses the coolant temp sensor, has two of the pipe stubs starting to push out. I will be removing them all tonight and rebonding them with jbweld, but the image above shows where the brown epoxy is now visible where the stub has started to work itself out. This would have undoubtedly let go in a big way at some point...
Other points to note
    You Can replace the coolant elbows without removing the main base coolant manifold. They are a little awkward to get to (well the one that is under the secondary HEX is, but its possible
    Dont expect Porsche to be able to supply all the parts you need.... on several occasions there have been parts or brackets I wanted that are out of stock, not in stock, not likely to be in stock for a loong time. Luckily I managed to work around this; but not possible for all parts eg turbo coolant lines
    Dont start a job like this and not expect it to run and run, I have now bottomed all the main issues, but I knew it would be a rats nest, 'I might as well do this, and that etc'
    Cleaning the front coolant manifold and all the other underside bits took a LONG time but I am a bit OCD with rusty items; but regardless of that, to make them clean and good to reseal took a significant amount of prep work.
    As above, a large part of the labour has been cleaning old parts for re use, mainly the coolant manifold but just getting some nuts off the underside was hard and I ended up having to cut the old lines to get them off (eg. the main oil return that runs between the cam covers)
So, just waiting on a couple of missing sealing washers but the rebuild is now underway once I have rebonded the remaining 3 coolant stubs. Hoping to get the engine ready to refit for 2 weeks time depending on what free time I get to do it. Then the fun starts refitting it and running/testing it. Just in time for winter Grin
Gazc2
Watkins Glen
PostPosted: Mon Sep 09, 2019 3:19 pm    Post subject: Reply with quote
Your not talking to yourself Thumb pretty sure I`m not the only one wathching this with interest and admiration,having spent the weekend wrestling rusty nuts and seeing some of the issues you are coming across the more age related issues were going to find with these cars unless you keep on top of them not a huge revelation I know but a timely reminder they need a bit of looking after.
2007 997 Turbo & 924s Restored
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
darkhorse
PostPosted: Mon Sep 09, 2019 3:27 pm    Post subject: Reply with quote
Thumb cheers Gazc2, someone else who feels the 997t pain Mr. Green
What did you end up ordering for your studs and nuts? (turbo ones..!)
I have just ordered some M8 copper locknuts off ebay, not entirely sure what other options there are?
are you doing coils and plugs per chance ? If so does anyone know where to get the thinner coil from for cyl6. My opc seems pretty inept, the spares manager is away on holiday and I cant get through all day on the phone lines... I ordered Beru's for the other 5!
Gazc2
Watkins Glen
PostPosted: Mon Sep 09, 2019 5:22 pm    Post subject: Reply with quote
I think I am just going to go with the standard studs from the OPC although I did find these titanium ones as an option and went with the nuts from merlin motorsport
https://www.merlinmotorsport.co.uk/p/k-nut-6-point-m8-x-1-25-k-nut-m8
https://titanclassics.com/product-category/nuts-and-bolts/titanium-studs/
not sure on a source for the coils I had mine done at my last service.
are you having to do the studs on your replacement turbos ?
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
darkhorse
PostPosted: Mon Sep 09, 2019 6:51 pm    Post subject: Reply with quote
Yes, saw those k nuts, the ones I have gone for are similar, just a little chunkier but copper and designed for turbos or manifolds.
No, the new turbos are only 5k miles old and from florida so they are immaculate;** update I checked in the boxes and all but one studs are missing** whoops
I do find it surprising that Porsche didn't use better suited materials for some of the low down studs, and bolts, but I guess UK weather is very hard on any car and any material!
Goto page Previous  1, 2, 3, 4  Next
Page 2 of 4
