991 : 2011- 19
997 : 2004- 76
996 : 1997-2005 35
993 : 1993-1998 7
Cayenne : 2003- 4
Satch
PostPosted: Wed Jun 26, 2019 1:52 pm    Post subject: GT3 Spoiler to Standard Spoiler - Need activation help. Reply with quote
Hi all. Hoping to call upon your expertise.
I have a 997.1 Carrera 4s (2006) which has the GT3 kit (including Rear spoiler from factory)
I have bought a 2nd hand rear deck lid and fitted it to the car to give it a more classic 911 look.
I knew that once the rear deck lid was fitted (which it is now) that I would need to activate the rear spoiler. I have Bought the Foxwell NT520 kit which is supposed to do activation on this car and spoiler.
According to the Foxwell NT520 kit, the spoiler is now activated (after a series of button pressing)
However the spoiler does not work at all. A few facts and tests I have done along the way.
1. The fuse is OK
2. When pressing the spoiler button (in cabin) it does not light up and the spoiler does not raise.
3. When looking at the live data for the rear spoiler button, the tool recognises that the button is being pressed.
4. when doing a component test for the button with the NT520, it lights up the spoiler button light, but the spoiler does not raise.
So I am wondering if anybody else has done this, and is there something else i am missing that needs to be installed or checked before the spoiler will work?
Could it be that the tool is just junk, and not actually activating anything (even though I get a message to say it is activated)
I know the PIWIS/Durametric is supposed to be able to do this function, but does the china clone kit do it or not?
Any help is welcome. Thanks.
Satch.
Porsche 911 997 C4s Speed Yellow
Porsche 986 Boxster 2.7 Arctic Silver
Porsche 911 991 C2S Carrera White - Sold
Porsche 911 996 Rainforest Green - Sold
Sy
PostPosted: Wed Jun 26, 2019 2:03 pm    Post subject: Re: GT3 Spoiler to Standard Spoiler - Need activation help. Reply with quote
1. The fuse is OK
Satch.
I’m usually the dangerous one with the tools so I’m sure there will be more confident people along to advise, but have you checked the motor which raises the spoiler? Is there current going to it? Can you pass voltage through it to activate it?
He who dies with the most toys wins!
Myasinax
PostPosted: Wed Jun 26, 2019 4:51 pm    Post subject: Reply with quote
Hi mate, the Foxconn unit is probably the best OBD scanner tool in its price baracket and is yet to fail me on a number of items I’ve used it for on my gen 2. I had an issue where the car display was showing drl lights activated, but they weren’t actually on. I had to turn them off as an option on the Foxconn and back on again several times before they activated and have worked flawlessly since. I’d suggest giving it a few goes and seeing if it resolves the problem. Other than that PIWIS or Durametric.
Good luck!
Blooders
PostPosted: Thu Jun 27, 2019 8:27 pm    Post subject: Reply with quote
Hi, I used a foxwell 520p to do the opposite and it worked first time to deactivate the spoiler. I had to go through a few menus to deactivate it. I removed the spoiler and before coding I had the warning beeps and message above 70! Not sure if this is the same unit you are taking about
2004 997 Manual C2S
Blooders
PostPosted: Thu Jun 27, 2019 8:31 pm    Post subject: Reply with quote
Another thought, the wireing loom is different for fixed spoiler and standard spoiler. I assume you new deck lid came with the correct loom? Not sure of the actual difference but worth a check
2004 997 Manual C2S
systech1
PostPosted: Fri Jun 28, 2019 12:42 pm    Post subject: Reply with quote
I too have used the Foxwell 520 to de-activate the spoiler lift after installing a fixed ducktail. And it should work the other way. I'm also wondering whether you have the correct wiring loom.
Long time Porsche fan. Previous cars include 911T 2.2, 911E 2.2, Carrera 3.0, 986 Boxster S. Current car is 997.2S Manual (with PSE, H&S Backbox bypass, Sports Chrono, SSK, DSC PASM controller, Carrera Sports wheels, Ducktail/Diffuser and splitter, Sport Design steering wheel etc.)
Satch
PostPosted: Mon Jul 01, 2019 9:40 am    Post subject: Reply with quote
Thanks for your input everybody.
The 2nd hand flat lid came with everything included, so the correct loom is already installed into the boot lid, so all i really needed to do was plug it into the engine bay port.
Sadly I have not yet found a fix for this.
I will be testing the motor inside the boot lid today hopefully to rule that in or out.
Does anybody know if the Durametric (not pro version) is able to activate the spoiler?
Also, does it look to you like this motor has had water damage or do they all look like this?
Thanks.
 Filesize:  104.78 KB
 Viewed:  614 Time(s)
 Filesize:  124.85 KB
 Viewed:  614 Time(s)
 Filesize:  133.73 KB
 Viewed:  614 Time(s)
