997 : 2004- 69
996 : 1997-2005 35
Boxster : 1997- 22
Newbe
PostPosted: Wed Jun 26, 2019 9:09 am    Post subject: Ignition Fault. I can pull the key out!! Reply with quote
Hi All
I was hoping someone has had this before and can advise?
I can pull the key out when the car is running 🤔
I'm looking at buying a new ignition switch? Looks easy to swap out?
Not sure if it needs programming or if I can use the same key?
Any ideas?
997 C4s
PostPosted: Wed Jun 26, 2019 6:56 pm    Post subject: Reply with quote
Yup you shouldn't be able to do that !!
It's just a lock with a series of switches in it .. it needs no coding and will accept any key you insert .. but the car wont start unless its the right key ... Transponder signal and not the key is what allows the car to start .
It's just about possible to replace without removing the lower panel .. i prefer to though .. i'm old and don't like agro Smile
Newbe
PostPosted: Wed Jun 26, 2019 7:00 pm    Post subject: Reply with quote
That's great cheers 👍
darkhorse
PostPosted: Wed Jul 03, 2019 4:40 pm    Post subject: Reply with quote
I had to do mine. Was exactly the same issue and as Demort says its straightforward. I did it without removing the lower panel but accepted that I was going to have to do some contortions to swap it out. Took about 20 minutes and job done
Newbe
PostPosted: Wed Jul 03, 2019 5:26 pm    Post subject: Reply with quote
I purchased the new switch and fitted yesterday.
I made a bit of a meal of it, probably took me an hour🤪
All done though and working as it should now, thanks for all your feedback 👍
PostPosted: Wed Jul 03, 2019 6:26 pm    Post subject: Reply with quote
There's nothing wrong with taking longer to do a job , especially if it's the first time you have done this .. i take longer on ANY job i do for the first time .
It's always best to be thorough and do a good job instead of rushing things i feel .
The inside of this lock actually has a small electrical winding which moves the locking pin holding the key in .. its this bit that fails .
job done , car fixed Thumb
Newbe
PostPosted: Wed Jul 03, 2019 6:36 pm    Post subject: Reply with quote
Onto the next problem.
Bent track rod arm👍
