Testing batteries was a whole lot simpler when I were a lad (queue the Hovis music) the only batteries found in cars were of the lead acid type and they had reasonably predictable issues when it came to fault diagnosis, add to that the simplicity of car electrical systems that had zero loading on the battery when the car was not in use, making battery assessments a whole lot simpler.
In Porsche terms I think the SC was perhaps the last to have the advantage of "simple" electrical systems..... But even then I suspect the primary cause of battery Porsche and other related electrical faults even in those with simple electrical systems may be down to LACK OF USE.
Neither automotive machinery or batteries were designed to lay dormant over the average of time spans that many Porsches experience today, either as garage queens or just recreational vehicles taken out on the road or track for an occasional BLAST.. Though there are batteries more suited to the task for stand-by generators etc.etc.etc. which are not suitable for use in vehicles..
Boat batteries suffered similarly irregular usage and then periods of high demand thus battery manufacturers created DEEP CYCLE lead acid (and perhaps gel..?) batteries to increase dependability in such situations. Whether deep cycle lead acid batteries might have a place in Porsches as opposed to ORIGINAL spec batteries, I leave that to those with a deeper knowledge of battery construction and use than I to determine.
It would seem that it is cheap enough to buy a "meter," but that does require an element of understanding to accurately assess the readings obtained, not only in terms of volts, ohms (resistance) or amps (current) but what part those readings play in the grand scheme of things relating to the that which you seek to understand..?
I have an old battery condition tester that has been very handy and is probably older than some of the folk reading this (if any) (-: I will try to post a couple of pics to give you an idea of it`s simplicity... handy for 356/912/early 911 owners up to the and including the SC models which had far "simpler" electrical demands.
My old battery condition tester operates by taking very accurate voltage readings during a predetermined series of SIMPLE tests during which a series of LED`s (light emitting diodes) will illuminate to provide the result of the test.
As has been typed here on many occasions battery voltage readings can look just fine but the battery fails under load, thus there seems to be much room for confusion...? It seems that to better understand the actual CONDITION of the battery the ideal is to perform a number of tests.
The LOAD TEST would seem to be perhaps the best indicator of battery condition..... ? Looking at the pic of my tester you will no doubt note that the wires to it are thin, and thus not at all suitable to carry the load that would be involved to assess the loadings a battery would be exposed to when trying to fire up a Porsche, however if you read the instruction set (a pic of which I hope to post) it can be seen that the LOAD in use during the test is that of the starter motor associated circuitry and components required to effect a real time start, the condition of the battery during that test is indicated by a LED being illuminated.
Thus it seems for many owners of older Porsches, a BATTERY CONDITION TESTER might just be a more suitable option than a "meter"....?
Testing has moved on from simpler tests used for lead acid batteries where a hydrometer could test the specific gravity of the electrolyte and give an indication of the state of charge. Many batteries are sealed these days, and some are gel filled consigning hydrometer tests to the bin... There are still available relatively cheap testers that can apply an actual LOAD directly to the battery to determine it`s CONDITION relative to expectations of it`s expected duties note the larger clamps and thicker cables.. It also seems there are still available testers similar to my old one, this link might be handy..?
https://www.eurocarparts.com/batter...MI2uyz0Y7_4gIV-ArTCh0f7ATIEAAYBiAAEgJbkPD_BwE
With later Porsches and their far more complex "intelligent" electrical systems, testing batteries while still connected to those systems is far more complex not only that but to disconnect the battery to simplify battery assessment can create a series of issues relative to creating fault codes and perhaps the loss of programming relative to personalised settings and accessory add ons, requiring a degree of re programming..as Kurlykris alluded to in his recent post 23rd June 19. Also notable from that posting is that it is recommended to pull the fuel pump fuse, perhaps to prolong the LOAD test by inhibiting start up..?
Of course "intelligent" chargers go some way to offsetting the seldom used syndrome that many batteries seem to suffer these days, but it seems the condition indication LED`s on these chargers can mislead at times too... ?
When I type of the complexity of modern systems, consider if you will Iain`s (Demort) also recent contribution 22nd June 19, where he informed us of the situation where an input to the electrical system is initiated by just operating the door handle to enter the car which then automatically energises the fuel pump to pre-pressurise the fuel system in preparation for the expected start up process... Thus from that it can be seen that battery loadings of modern vehicles differ significantly from those of earlier Porsches thus assessing battery condition is also potentially a more complex issue when even to open the frunk to gain access to the battery terminals in a bid to test the condition of the battery, you have already drained a measure of potential from the battery....?
There are non-professional (cheaper) battery condition testers still available that measure voltage to assess the condition of the battery while using the vehicles on board systems to provide the very necessary LOAD TEST.. though I have no experience of them... however as with all test regimes it is important to follow the instruction set to the letter in order to obtain an accurate assessment.. it might be worthwhile to look at this link..?
https://www.amazon.co.uk/s?k=batter...827852&tag=googhydr-21&ref=pd_sl_4r1g56h4su_e
If interested, to give you an idea of more professional kit you might like to beam up :-
https://www.rotronicsbms.com/produc...MI2uyz0Y7_4gIV-ArTCh0f7ATIEAAYAiAAEgIsmfD_BwE
As ever I am just passing time thinking in type and happy to be corrected should my thinking be considered flawed.. I am no expert. :?:
