I Thought i Had Seen It All .
Monaco
21 Mar 2015
11,244
Boxster in for a water leak .. rear drain blocked and door panel damp at the base .. a membrane leaking .
Went to remove the door card , all screws out but i couldn't get it to release .. rather strange .. had a closer look .. we do these on the floor so i'm now on my back looking up at the door card .. there's silicone on the door card .. a bit confused here ..
The door card has been siliconed in place .. this is a WTF moment !
a lot of gentle levering with a plastic trim tool .. trying to cut the silicone i finally manage to remove it ..
Pictures below kinda explain it from here ..
Someone had used 3 different types of silicone to stop a water leak rather than replace the foam membrane .. the original glue was still on the door which had reacted with the silicone .. in most places it was just a sticky mess .
A blade to cut of the larger parts .. 1 cm depth in places .. then a carousel wheel .. we use it to remove the wheel weight rubber when fitting new wheel weights ..
I burnt out an entire wheel removing this mess .
never seen a door card glued in place to stop a water leak before .. had me smiling until i had to remove it all .. lets just say i was covered in the stuff after this ..
Respirator .. goggles , glasses .. gloves etc ..
pictures tell it all i guess :D
very strange way to stop a leak .. the different silicones got me .. i can only assume it was more than one attempt to stop a leak .. i'm afraid bathroom sealant wont work on this sort of problem .. that was the top layer .
Right click and either view image or view in a tab to get a larger view .. i think its at its best in a full picture .
There is some freaks out there! :dont know:
What a mess!!
I've heard of this type of repair before, usually by people who are running these on a shoestring.
Glad I did mine the proper way!
How gutted would you be to have that bodge job revealed on your pride and joy?
I have to say .. if you use chrome then load the first image in a seperate tab .. then zoom in .. you will get the full appreciation of how thick it is in places .
I'm guessing a membrane replacement on its own is 1 hr .. i think we get 1.5 to do a window reg .
The biggest headache is always getting the old glue off .. that's the only time consuming part of the job , i doubt these membranes are that expensive either .
All i can say though is it turned into about a 3 hour job plus parts to replace it !
Butil if you are going down the cheap route and i do understand cost implications as not everyone has deep pockets .
Butil but not silicone please :D
EDIT ..
Just to add .. if you carefully use a stanley blade and cut the old glue you can reuse these membranes .. a bit tricky but it can be done .
124,554
1,441,464
48,967
Max V
