997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
Richtw
PostPosted: Wed Jun 19, 2019 7:52 am    Post subject: Sport Chrono on manual? Reply with quote
Ok so after a selling my 997.2 C4S and then a short dabble with a 991.2 GTS (now sold as I just did not get on with it, too big, too comfortable, just a competent everyday car really) I am back in the market for another 997 Smile
What is the situation with manual cars and Sport Chrono? I have seen a good manual but does not have Sport Chrono - could this be specced on a manual or just PDK?
Thank you....
2017 991.2 GTS
2010 997.2 C4S
The return of Marty Wild
PostPosted: Wed Jun 19, 2019 7:57 am    Post subject: Reply with quote
I’d say the car just isn’t sporty enough without the throttle response ‘Sport Chrono’ provides. You can put a ‘Sprint Booster’ aftermarket part to achieve a similar throttle response on non Sport Chrono cars.
Boxster S 986.1
Cayman S 987.1 (gone but not forgotten)
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Wed Jun 19, 2019 8:13 am    Post subject: Reply with quote
my understanding is that you can have the sport button retro fitted, albeit without the dash clock, and that this can then be coded to give the same change in throttle response (and PSE if fitted)
jpsh120
PostPosted: Wed Jun 19, 2019 11:11 am    Post subject: Reply with quote
Yes, you could have sport chrono on a manual car.
My 2p worth....I had it and wasn't keen. The throttle is much more sensitive with it on and for me OTT for road use.
I know a lot of people love it though, so you would need to try one and make your own mind up.
The brochure extract below shows the difference between normal and sports mode (throttle), it's sometihng like 20% less travel for the same effect.
2007 997 Carrera S - SOLD Sad
Poker2009
PostPosted: Wed Jun 19, 2019 4:42 pm    Post subject: Re: Sport Chrono on manual? Reply with quote
Just as I suspected..
997.1 C2S, black, coupe, manual, Feb '05:
63k miles, tiny IMS bearing, Millers NT+ 10W50, driven above 3000 RPM.. original engine.
PostPosted: Wed Jun 19, 2019 4:52 pm    Post subject: Reply with quote
My manual has chrono, , I like it and it does sharpen things up on the car, it can as others have said be retro fitted with the button but not with the clock which is no loss as the clock is just a useless gimmick , So if you have found the right car but no chrono just factor in the £800/£1000 to have it fitted , as mentioned also I had a sprint booster on my gen1 and that has a similar effect it fools the car into thinking your driving more aggressively than you are although IMO the sprint booster is much more noticeable on tip cars as it stops the tip box from learning and adopting a lazy style when normal driving around town. Thumb
SJD
PostPosted: Wed Jun 19, 2019 7:18 pm    Post subject: Reply with quote
C4S manual with chrono. First thing I do before setting off is to select sport mode and PASM off. Noticeable difference in response. Car feels lethargic without it.
Kettmark
PostPosted: Wed Jun 19, 2019 7:30 pm    Post subject: Reply with quote
How much is the sprint booster?
Thefinn
PostPosted: Wed Jun 19, 2019 7:31 pm    Post subject: Reply with quote
I have a manual 4s with chrono, if I am on open roads I do like it on all the time as the car feels much more responsive but in traffic or around town I find it a little jumpy when you try for a light press of the pedal, so turn it off. If you do get a chrono car though you will also end up wanting a dsc module so you can switch the PASM on, off, sports otherwise you can not have the chrono on without sports pasm on or vice versa.
997.1 C4S CAB
rob_p
PostPosted: Wed Jun 19, 2019 8:02 pm    Post subject: Reply with quote
Same here. I never use mine - I just find it a bit jerky. Not much wrong with then standard throttle response in my mind. Each to their.
That said, I really like the wart which other don't!
991.1 C2 (no mods, yet)
Jeep Grand Cherokee WK2
Ex Porsche Boxster 986
Ex Mazda MX5 mk1
Gray79
PostPosted: Wed Jun 19, 2019 9:56 pm    Post subject: Reply with quote
My C2S manual has Chrono, and the first thing I do every time i start it is press the sport button on, shortly followed by putting the suspension back on the softer setting. Makes the car feel so much more responsive, also it turns on the pse Very Happy
997.1 Carrera 2S
Magic919
PostPosted: Thu Jun 20, 2019 6:15 am    Post subject: Reply with quote
You can’t really turn PASM off, it’s always on.
997.2 C4S PDK
arthouse
PostPosted: Thu Jun 20, 2019 8:37 pm    Post subject: Reply with quote
True, it's PASM 'normal' or 'sport'.
I've got a .2 manual with Chrono and PASM. I don't use the sport mode much, i actually forget i have it sometimes, but it works better on B roads than around town and another definite benefit is blipping the throttle/heel toe is easier at higher engine speeds.
Mine has the PSE too but it doesn't turn on when i press the sport button, maybe that's a .1 thing?
Magic919
PostPosted: Fri Jun 21, 2019 5:27 am    Post subject: Reply with quote
Yes, 997.2 doesn’t switch on PSE with Sport mode.
I don’t have a manual and Sport mode doesn’t always suit the PDK. I like the throttle response and it’s a good way to stop the car heading for 7th quite so quickly. It’s great for the Autobahn when you get a chance to nail it.
997.2 C4S PDK
wjk_glynn
PostPosted: Fri Jun 21, 2019 10:50 am    Post subject: Reply with quote
Another .2 difference is that RWD Carrera coupes received brake pre-fill.
Sports mode disables that on the .2 cars.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Brake Airflow (996 GT2 front scoops, 997 Turbo rear scoops, 997 GT3RS rear L-ducts) • 3rd (center) Coolant Radiator • TG Muffler Bypass
Jonathon555
PostPosted: Wed Jun 26, 2019 6:36 pm    Post subject: Reply with quote
My .2 c2s manual has chrono and until reading this I did not know what it did. I knew on the pdk what it did but could not fathom its use on a manual.
Will give the sport button a press
996 Turbo manual
997.2 C2S manual
E46 m3 manual
And others .....
