991 : 2011- 19
997 : 2004- 77
996 : 1997-2005 35
993 : 1993-1998 7
Cayenne : 2003- 4
Gray79
PostPosted: Tue Jun 18, 2019 8:31 pm    Post subject: Porsche Colander Reply with quote
Only had it since the beginning of May and just repaired my fourth coolant leak nooo
First one blew a hose off on the top of the engine behind the air box (I put this down to it not been clicked back in properly after the engine rebuild last year), then the hoses at the front end were all corroded, so had to replace them, then a heater hose was leaking due to the jubilee clip been over tightened and stripped and now a plate on the bottom of the engine started to leak, so I had to remove it and put a smear of sealant on it.
I suppose all apart from the corroded hoses I can put down to the engine rebuilders, but it’s not doing much for my confidence in the car, only done about 300 miles in it!
It’s a good job I’ve got my own car lift.
997.1 Carrera 2S
kurlykris
PostPosted: Tue Jun 18, 2019 8:52 pm    Post subject: Reply with quote
Was the car regularly used before you took ownership Question
I`ve come to the conclusion that these watercooled Porsches do not like being left standing and not being used, this is when these sort of problems occur, lack of a good regular thrashing Grin
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
Gray79
PostPosted: Tue Jun 18, 2019 8:56 pm    Post subject: Reply with quote
I’m beginning to think your right, it’s only done 54k miles, and the last owner only did about 3k a year (same as what I’ll probably do).
997.1 Carrera 2S
kurlykris
PostPosted: Tue Jun 18, 2019 9:07 pm    Post subject: Reply with quote
I try to give my pair at least one good heat cycle per week, with some high speed country lane driving and a bit of dual carriageway for good measure. My 996 was being a bitch since getting her out for the MOT in March, idling issues and stalling, now I`m using her again she`s running sweet as a nut, so I won`t be putting her away for winter next time nooo
Gray79
PostPosted: Tue Jun 18, 2019 9:20 pm    Post subject: Reply with quote
I just don’t get time to drive mine that much, although I do try and get it out at least once a week.
997.1 Carrera 2S
PostPosted: Wed Jun 19, 2019 6:51 pm    Post subject: Reply with quote
Hose not fully clipped in place .. i'm afraid it does happen .. its a bit of a silly system that a small locking pin for want of a better word holds a lot of pipes in place on these .
I tend to give them a good hard pull after fitting to make sure its seated ok .. we learn from mistakes im afraid .. not one i've made in many a year .. you only do this once .. but i agree .. once is too many Embarassed
Front cross over pipes corroding is kinda normal i'm afraid .. that's a design / our crap weather plus salted roads for you .. a lot of the pipes are protected so it's only a few that are exposed .
Your other 2 faults are unusual .. so i feel you have been a bit unlucky there .. it does happen .. i see faults now and then that i'm pretty sure i will never see again .. that i realise doesn't help you but over all these are pretty good cars with some faults ..
Any make of car will have faults .. i'm afraid Porsche is no different .
Hopefully you can now drive the car with no further problems .
timbo1811
PostPosted: Thu Jun 20, 2019 7:12 pm    Post subject: Reply with quote
As Demort says, I think you've been unlucky, I don't subscribe to the 'good thrashing' lobby but I would say if you do take it out make sure the oil gets to temperature particularly in the winter to remove any condensation, other than that some preventative maintenance would be a good idea.
Lotus Elan, Lotus Elan +2, MGA Mk11, TR4, 230 Compressor, 320 coupe, 944, Boxster 2.7, 997.1(current), VFR 1200, CBR 1100 Blackbird
Gray79
PostPosted: Sat Jun 22, 2019 9:28 am    Post subject: Reply with quote
I was hoping to not have to do too much to it this year, enjoy through the summer, then get it on the lift this winter and give it a thorough going through, but so much for best laid plans Sad
997.1 Carrera 2S
timbo1811
PostPosted: Sat Jun 22, 2019 1:10 pm    Post subject: Reply with quote
Well you could enjoy until late September I would have thought, that's if we ever get a summer !
