991 : 2011- 19
997 : 2004- 77
996 : 1997-2005 35
993 : 1993-1998 7
Cayenne : 2003- 4
Jam911
PostPosted: Tue Jun 18, 2019 9:40 am    Post subject: Replacing Diff Oil Seals Reply with quote
Apparently my diff oils seals have a leak and need replacing.
Has anyone had this done and how expensive is it?
Current '07 997 C4S
Ex '99 2.5 Boxster
PostPosted: Tue Jun 18, 2019 9:43 am    Post subject: Reply with quote
Oil and diff can be removed in under an hour. New seals then pressed in and back together. Note each side is a different size seal. Then replace the diff and fresh gearbox oil. Might want to check/replace diff bearings at the same time. I'd say around 4 hours labour.
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Tue Jun 18, 2019 9:50 am    Post subject: Reply with quote
I had the NS seal done on mine last month, cost £160 at Quorn sports and classics Thumb
Jam911
PostPosted: Tue Jun 18, 2019 11:10 am    Post subject: Reply with quote
Thanks for the info
Current '07 997 C4S
Ex '99 2.5 Boxster
