Nordschleife
- Joined
- 6 Mar 2014
- Messages
- 22,175
My doors drop slightly when opening and also don't close as 'smooth' as they should. After reading an old thread on here, there is a chance the bolts that lock the door hinges into the brackets on the car may be loose. I've tightened these up before and it has improved them so thought I'd first give that a go.
Anyway, as luck would have it I snapped the top bolt in the hinge :duh:
You can see the bolt I mean here on the underside of the hinge and bracket:
Although a bit of a pain, it's now made me investigate further to see what the issue is. So I propped the door up with an upside down bucket and piece of foam and removed the hinge from the door. Once the torx bolt was removed, the hinge just lifted out the taper it sits in on the bracket.
Here you can see the taper that locks into the bracket and the remains on the snapped bolt:
Well at least I know how the hinge works now. The tapered part sits in the taper in the bracket and is locked in position by the bolt from the underside. The hinge then spins on the central tapered post or so it would seem.........and that is where the play is. I can very slightly rock the central piece in the hinge. Not much, but over the full length of the door it equates to a few mm. So tomorrow at work I'm gonna have to fathom out how that central post is locked in the hinge and also what I need to do to remove any play in it.
Should be fun!! And once I've done that I'll probably work my way through the other 4 hinges and get them all bob on so I have super smooth shutting doors :yahoo:
