997 : 2004- 66
Boxster : 1997- 31
PindiXpress
PostPosted: Tue Jun 18, 2019 3:51 pm    Post subject: Reply with quote
Enthralling read as always H. Shame about the original lump, must have been very frustrating. Modified cars eh.
As an aside, would be interested in buying the paddle clutch if you still have it.
Slippydiff
PostPosted: Tue Jun 18, 2019 4:24 pm    Post subject: Reply with quote
The PO swapped it for the 4.0 RS item, it had no place in a road car, all the moreso when OE, completely streetable options are readily available.
It was a very strange choice, but having seen the innards of the Frankenstein engine and its install, perhaps not that strange ...
DynoMike
2003 Porsche 996 Turbo
PostPosted: Tue Jun 18, 2019 6:42 pm    Post subject: Reply with quote
At Last Henry, this has been a long time coming! What a fabulous car and equally fabulous write up, I salute you, Sir Salut
I saw the bodgery that had taken place first hand. Truly shocking levels of 'preparation', the poor original owner must have been tearing his hair out, paying premium prices for back street quality.
You are quite right about many engine tuners being t**ts, most these days simply rely on google to supply their knowledge. In the case of your car's original 'tuner', I feel that supplying his racing budget for the year took precedence over building what surely would have been (and now is) the finest Mark 1 GT3. Shocking. The guy had no morals and even less conscience.
But, just look at what you have now..... what an epic and seriously beautiful car you now own. To my eyes, it sits perfectly. Zanzibar surely is the prettiest of all Mark1 colours?
I look forward to seeing it in the flesh soon, assuming this pesky rain disappears.
Thank you so much for sharing this with 911uk, this forum has a good number of modified cars onboard. Yours must sit at the top of the tree though!
Mike.
2003 996 Turbo
Previous toy 1974 Mini 1000
Slippydiff
PostPosted: Wed Jun 19, 2019 6:32 am    Post subject: Reply with quote
Morning Mike, I hope you’re well ?
Yes, this weather has rather put a dampener on proceedings. I did get caught in a couple of heavy downpours whilst out in the car on Sunday evening. I must admit I’d harboured some concerns over driving the car in the wet, but they were ill-founded, and even with it’s current slightly compromised geo set up and ride heights, the car was grippier than expected and fun/confidence inspiring to drive. Though the brand new rear Cup 2’s may have played a significant part in that !!
For those interested, here’s the final dyno plot after mapping, if you squint hard enough you can just make out the headline figure :
Those of you wondering about the levels of “bodgery” Mike and I are alluding to, may like this gem.
The car was fitted with some very expensive, circa £8K, JRZ 3 way adjustable, remote canister dampers.
Bearing in mind the significant cost of these items, you’d have thought some time, effort and maybe even a bit of care would have gone in to mounting the canisters ? Perhaps use some good quality billet alloy brackets to mount them securely ? And locate them where they could be easily accessed, perhaps even “on show” ?
But no, cable ties and double sided foam tape were clearly the only things to hand that day ...
To make access to the compression adjusters possible, the plastic scuttle tidy panels had been drilled, hacked and bludgeoned accordingly.
Unfortunately the resultant “openings” were in the wrong place for the adjusters, so despite ruining over £100 worth of plastic mouldings, the original objective failed miserably.
When you consider removing the battery cover takes all of 5 seconds, and if the retaining screws and their rubber/brass inserts in the flitch panels are properly maintained, the scuttle tidy panels take all of a minute a side to remove, this attempt at a “quality install” looks less than well thought out, or indeed convincing ...
Regrettably pretty much every aspect of the car that had been modified (or indeed worked on) was similarly bodged.
Diggermeister
PostPosted: Wed Jun 19, 2019 12:06 pm    Post subject: Reply with quote
Slippydiff wrote:
...so you’ll be seeing it over at Paul’s Digga, as he said he’s expecting your car in this week ?...
A front bumper on yours and the minutest of scuffs on the rear bumper of mine. I like to keep it looking pristine!
Slippydiff
PostPosted: Wed Jun 19, 2019 8:43 pm    Post subject: Reply with quote
coullstar wrote:
Oh god yes you need to, turning into my favourite ever 996 for sure!!! Just paint it cobalt and your done Laughing Thumb
Cobalt you say ?
Hmmm, the Cup engine into this :
Proper (the best ?) 996 hotrod...
coullstar
PostPosted: Wed Jun 19, 2019 9:19 pm    Post subject: Reply with quote
Looks a bit like mine, Id settle for the engine.
 Filesize:  917.59 KB
 Viewed:  2138 Time(s)
DynoMike
PostPosted: Wed Jun 19, 2019 9:32 pm    Post subject: Reply with quote
All good here thanks H. The power curve is ideal, the plateau at the top is what we look for, as when you change gear in the higher ratios the motor is still producing its maximum thrust. When viewing power vs speed through all gears, typically on a Dynojet 'dyno' (not my favourite by any stretch), the power plateaus become very evident. Much area under the curve! Kudos to Wayne for his diligent work there, excellent stuff!
I hadn't seen those particular gems of damper butchery, what on earth was the thinking behind it?Other than making the quickest buck possible that is..... Grim.
I read one of your other posts about the comfort levels afforded by Cup2 tyres, I've found exactly the same thing on my Turbo, way quieter and more comfortable than the PS2s the car had worn previously. The exact opposite of what I had expected and a most welcome addition, not to mention the hugely increased grip thumbsup
2003 996 Turbo
Slippydiff
PostPosted: Wed Jun 19, 2019 11:05 pm    Post subject: Reply with quote
That, is lovely. Cloud 9
Ducktails look so good on a N/B 996 coupe.
Slippydiff
PostPosted: Wed Jun 19, 2019 11:23 pm    Post subject: Reply with quote
Evening/Morning Mike. I can definitely vouch for the fact it's still producing its maximum thrust when you change gear in the higher ratios Surprised
I've been out in the car for a few hours this evening, luckily I managed to find a window in the rain and thus had three hours of bone dry tarmac on which to scrub the Cup 2's in. As you've said, grip aplenty, though I think they have their work cut out on the GT3 !!
I'm slowly getting to grips with the car and it's brakes, suspension, power delivery etc. With the Ohlins warmed through (and the tyres) it's an amazing piece of kit, all in all very similar to my old Manthey K400 car, but with a healthy dose of extra grunt.
I'll PM you to make arrangements for you to experience it first hand from the passenger seat Mr. Green
Slippydiff
PostPosted: Mon Jun 24, 2019 12:36 pm    Post subject: Reply with quote
As promised ...
Open Youtube Page
And if the above doesn't work :
https://www.youtube.com/watch?v=NaxtAinCsiM
DynoMike
PostPosted: Mon Jun 24, 2019 6:20 pm    Post subject: Reply with quote
Ear-gasmic!! What a sound Cloud 9
When all cars become electric, even duller than they are nowadays, I hope to God that petrol is still available so you can drive that car and awaken the brain-dead!! Superb sound track....
The idle is very choppy - much worse than I anticipated, but once under the minutest load it seems to pull cleanly and without drama.
Oh yes indeed, I'll take a ride in the car at some point this year, just let me know a suitable weekend. I won't be able to get in if you have a front cage fitted, sadly.
2003 996 Turbo
coullstar
PostPosted: Mon Jun 24, 2019 6:38 pm    Post subject: Reply with quote
Surprised worship
Slippydiff
PostPosted: Mon Jun 24, 2019 6:39 pm    Post subject: Reply with quote
Hi Mike,
The choppy idle is pretty standard for a 996/997 Cup :
1.30 onwards here :
https://m.youtube.com/watch?v=FfDlrCI0ysw
and as we discussed is a function of the duration/overlap of the cams that allow it to breath so well at the top end (as you can hear from the video...)
Wayne controls the idle with the Motronic’s ability to advance and retard the timing quickly at idle and thus avoid stalling.
Once warmed up from cold (3-4 minutes) and on the move, the power delivery is pretty much seamless all the way to redline.
Strangely the idle of the Mk 1 GT3 was always very lumpy compared to the Mk 2, perhaps due to infinitely variable Variocam and a more powerful ECU on the later car ? Personally I always thought it imbued the car/engine with more character, and the Cup engine echoes the rough tickover (almost like a cylinder or two drop out every 10 rotations of the crank) of the standard car.
It can be heard in the last 5 seconds of this clip of my old Manthey K400 converted car :
https://m.youtube.com/watch?v=PeHWqBAt_rk
LaSource
PostPosted: Mon Jun 24, 2019 8:14 pm    Post subject: Reply with quote
Slippydiff wrote:
LaSource wrote:
Wow - a bit of a journey for you but a very cool destination!
First dibs on when you want to move it on Very Happy
...oh, and we really must take it to a circuit to benchmark it. First dibs on helping out with that Very Happy
Love it - proper cup car on the road!
Done T ...
(in exchange for a minimum of 20 hours photography tuition) Mr. Green
Done!!
997 GT3 RS 3.8 Grey/Red
996 GT3 Mk2 Clubsport Guards Red
KTM XBOW RR Superlight Spec
BMW E39 M5, BMW E46 M3
Land Rover Discovery 4 HSE
Previous:
981 GT4 3.8 Clubsport
2x 997 GT3 RS 4.0 White and White
2x 997 GT3 RS 3.8 RHD and LHD
2x 996 GT3 RS Blue and Red
2x 996 GT3 Mk2 Clubsport and Comfort
Y2K
PostPosted: Tue Jun 25, 2019 11:09 am    Post subject: Reply with quote
Sounds great at 60 mph Smile
2005 996 GT3 mk2
1999 Integra DC2
Slippydiff
PostPosted: Tue Jun 25, 2019 12:23 pm    Post subject: Reply with quote
Allowing for speedo error and a 10% allowance before the BiB get awkward, I reckon that 66mph and not a single mph more ... Mr. Green
Kev.K
PostPosted: Sun Aug 11, 2019 2:41 pm    Post subject: Reply with quote
And I thought building a house was stressful and expensive.
Awesome car.
IMI A
PostPosted: Sun Aug 11, 2019 2:59 pm    Post subject: Reply with quote
One of the best sounding cars I’ve ever heard.
Slippydiff
PostPosted: Sun Aug 11, 2019 7:53 pm    Post subject: Reply with quote
Awesome car.
Trust me, fettling a car such as the GT3 is child’s play compared with building houses !!
Page 2 of 3
