997 : 2004- 69
996 : 1997-2005 35
Boxster : 1997- 22
Aphill80
PostPosted: Mon Jun 17, 2019 11:17 am    Post subject: 997 Spacers - So many options Reply with quote
Hi all,
I have a thread running i.e lowering springs, I have decided to go with the H&R kit and they are being fitted next week.
I understand spacers, 7mm front 15mm rear and hub-centric but there are so many brands! and kits but no one sells a kit in different front and rear fitment
so can someone just cut through all the options? I have gone and confused myself now.
• Where is the best place to get?
• What size bolts do i need
• Ideally i still want locking wheel nuts
• Spacers can be Black or silver..
• BUT the bolts need to be black as i have black wheels...
Some help would be great..
Andy
paul284pt
PostPosted: Mon Jun 17, 2019 1:09 pm    Post subject: Reply with quote
Hi Andy,
H&R do great magnesium alloy spacer kits for both front & rears separately, depending on what you want. it would make sense if you used them, they are also very light being magnesium alloy. If you new longer studs are recommended the kits come with them as standard, so no worries there. With the correct studs it wouldn't matter what colour as they would be hidden by your existing wheelnuts anyway. You may need to source if you want the studs exposed beyond the nuts (racing style) but you would then have problems with security for your wheels, there are plenty of people with light fingers around.
I have H&R 7mm on the front of my 964 and 18mm on the rear.
You can order direct online or I bought mine from Simon at JZM (Parts Dept.) who could give you some advice.
Cheers,
Paul
1980 - 84 924 Turbo with mods. (ex Tony Dron - 12th at Le Mans 1980 with works 924 Carrera Turbo).
1984 - 89 911 SC (1982)
1989 - 93 911 Carrera Sport (1989)
2010 - 964 Carrera 2 (1990) Redtek 3.8RSR
2012 - 14 Porsche Cayenne (2012)
2015 - 17 Porsche Cayenne Diesel S (2015)
2017 - 18 Macan Turbo Performance Package (2017)
2018 - 991.2 Carrera 4 GTS (2018)
PostPosted: Mon Jun 17, 2019 3:55 pm    Post subject: Reply with quote
Andy , whenever I need any bolts etc I call these guys , tell them your alloy and spacer size they seem to know Porsches well so always send me the right things , they should also do the longer security bolts as well
https://projexuk.com
NLW73
PostPosted: Tue Jun 18, 2019 5:39 pm    Post subject: Reply with quote
anything above 5mm you are going to need longer bolts of course. you need 5 full turns of the bolt to be sure.
anything over 10mm I would be looking to go hubcentric so you bolt the spacers to the hub and then the wheels to the spacers on the hub using OEM bolts and locker.
I do that for my winter wheels with 15mm all round.
sth like this on fleabay is ideal:
https://www.ebay.co.uk/itm/5x130-CBH-71-6-20mm-BLACK-Hubcentric-Wheels-Spacers-to-fit-Porsche-911/113054436546?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D80f7fb40424d4b2298c003e4f697a634%26pid%3D100675%26rk%3D2%26rkt%3D15%26sd%3D113773857691%26itm%3D113054436546&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3Ae18b3a76-91ef-11e9-91dd-74dbd180f24d%7Cparentrq%3A6bab295d16b0aad37a9432f8ffcdfdca%7Ciid%3A1
997 C2s Schwarz
Aphill80
PostPosted: Wed Jun 19, 2019 12:06 pm    Post subject: Reply with quote
paul284pt wrote:
Hi Andy,
Cheers,
Paul
thanks Paul, it seems the H&R ones for the 7mm and 15mm sizes on a 997 need longer bolts,
bolts i can get in new lengths from Design-911 but longer locking nuts is proving harder
A
MaxA
PostPosted: Wed Jun 19, 2019 12:34 pm    Post subject: Reply with quote
I'm running a stud conversion (wit Porsche Motorsport parts) which makes adding and removing rims and spacers about 200x easier than fooling around with bolts. Just a thought.
NLW73
PostPosted: Fri Jun 21, 2019 4:09 pm    Post subject: Reply with quote
Aphill80 I just got these from ebay and they are spot on.
fitted them earlier and they are a great finish and quality.
the bolts they supply attached the spacer to your hub and then you use you OEM bolts and locker to attach the wheel to the spacer.
secure and much better than longer bolts:
997 C2s Schwarz
