991 : 2011- 19
997 : 2004- 76
996 : 1997-2005 35
993 : 1993-1998 7
Cayenne : 2003- 4
wildej
PostPosted: Thu Jun 13, 2019 3:53 pm    Post subject: Lower Dash Panels Removal Reply with quote
Hi Guys,
Are the lower dash trim panels easy enough to remove ?
Does the whole glove box need to come out or can you just remove the cover to it ?
Also any tips for removing the part around the ingition and light switch ?
997 GTS
Previous
991.1 C4S
997.1 Turbo
997.2 C4S
997.2 Carrera
brownspeed
PostPosted: Thu Jun 13, 2019 4:05 pm    Post subject: Reply with quote
I had the OS lower section (Ignition and light switch areas) off a couple of years ago to access the relay panel. IIRC its fairly straightforward as long as you can locate the screws and clips. Don't try forcing anything apart.
2004 997.1 C2S (Hartech rebuilt)
2002 TVR Tamora 3.6
1990 Mini Cooper RSP
Abarth 595
stucart
PostPosted: Thu Jun 13, 2019 5:13 pm    Post subject: Reply with quote
I did mine but I had replacements to guide me where the screws were, from memory you can remove the glovebox front section separately, there are 2 screws behind the light switch, that slides out if you push it in and turn it to the vertical if that makes sense,(releases two tabs that hold it in) sure there are tutorials on YouTube.
2 screws hidden on top of steering wheel binnacle also I seem to remember.
Go gentle , good luck.
Stu.
Now - Jaguar F-Type 2014 3.0 S Quickshift ,White/ Red interior (theme here!) Loving it .
Previously - 997 C4S Tip-S, 2007, Silver/Red and Black Leather, PSE, Sports Chrono, Turbo wheels.
