997 : 2004- 62
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 20
Cayenne : 2003- 7
Jam911
PostPosted: Fri Jun 07, 2019 6:40 pm    Post subject: Transmission and Diff Oil Change Costs ??????? Reply with quote
I had my transmission and diff oil change done today.
My Indy said to use OPC Oil as he wouldn't want to put any other oil in.
Jeez the oil is expensive at £180 !!!
Thankfully it is only done once every 12 years
Current '07 997 C4S
Ex '99 2.5 Boxster
PostPosted: Fri Jun 07, 2019 6:49 pm    Post subject: Reply with quote
The oil isn't expensive, the profit margin is.
Jam911
PostPosted: Fri Jun 07, 2019 7:05 pm    Post subject: Reply with quote
True. Porsche Tax
Current '07 997 C4S
Ex '99 2.5 Boxster
-- 997 --
PostPosted: Fri Jun 07, 2019 7:53 pm    Post subject: Reply with quote
Quick question, does the gearbox oil catwr for the diff or are they seperate??
J
PostPosted: Fri Jun 07, 2019 7:59 pm    Post subject: Reply with quote
Rear diff shared with gearbox, front diff separate.
Jam911
PostPosted: Fri Jun 07, 2019 9:05 pm    Post subject: Reply with quote
I had both done
Current '07 997 C4S
Ex '99 2.5 Boxster
marko343
PostPosted: Sat Jun 08, 2019 3:59 pm    Post subject: Reply with quote
DIY job?
-- 997 --
PostPosted: Sat Jun 08, 2019 5:09 pm    Post subject: Reply with quote
Excellent, thanks !! I guess its for C4 then !!
J
PostPosted: Sat Jun 08, 2019 5:32 pm    Post subject: Reply with quote
'07 997 C4S according to the OP's signature.
chowgar
PostPosted: Sun Jun 09, 2019 2:09 pm    Post subject: Reply with quote
When I did my tranny oil a couple of years ago, I used the Millers NT fluid. If this brand is good enough for my engine, it should be as good, if not better than the Porsche oil. I've had no issues with my gearbox, including any noises, shifting is smooth and during cold weather periods, it warms up fairly quickly too.
