997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
Albionmuz
PostPosted: Fri Jun 07, 2019 12:05 pm    Post subject: Horn honking when you brake? Reply with quote
I have had this incredibly embarrassing thing happen to me a number of times. Brake to let oncoming traffic through whilst hooting at them for having the temerity to make a 993 wait (that’s what it must sound like!).
It’s a common fault apparently and means the airbag retaining bracket rubbers have deteriorated.
Had this happen recently three times on country roads through Kent villages and eventually stopped and pulled the relay. Apparently a credit card wedged in the gap at the top of the steering wheel would have worked I found out afterwards.
Anyway getting this fixed next week.
Anyone else had this happen to them?
993 Targa manual
Alfa GTV Twinspark
Citroen Deux Chevaux
Alfa 159 Sportwagon
Porsche 968 Cab Tip
Lexus IS 200
Endoman
PostPosted: Fri Jun 07, 2019 1:19 pm    Post subject: Reply with quote
Very common on 944s caused by weak horn springs
gunner
PostPosted: Fri Jun 07, 2019 1:23 pm    Post subject: Reply with quote
My horn sounded every time I changed gear after I mismatched the tip shifters and the horn earth...
Laughing
993 C2 Tip Aventura
decgraham
PostPosted: Fri Jun 07, 2019 3:01 pm    Post subject: Reply with quote
Yep had the same problem many years back, probably for me the heat in Q8.
Link below explains the problem and a fix. Thumb
Cost of parts will be a bit more today I'm sure. Evil or Very Mad
http://forums.pelicanparts.com/porsche-964-993-technical-forum/556487-993-horn-issue.html
ATB Smile
ToreB
Approved Trader
PostPosted: Sun Jun 09, 2019 2:48 pm    Post subject: Reply with quote
Common problem. You need new horn bushings.
You can either buy a new aluminium air bag frame from Porsche and hope that it fits your steering wheel. If not, you just pop out the bushings and use them on your existing frame.
Bushings are also available here:
http://www.allzim.com/store/horn-return-bushings-993.html
Cheers,
Tore
'95 993 C4
Bergvill F/X
Porsche electronics specialists, products and repair services.
Cameltoe & Heel
PostPosted: Tue Jun 11, 2019 7:17 am    Post subject: Reply with quote
Yes I have the same issue but it happens when turning left usually...ordered a new frame with rubbers from Type911.
Trev
