991 : 2011- 19
997 : 2004- 76
996 : 1997-2005 35
993 : 1993-1998 7
Cayenne : 2003- 4
Desert Dragon
PostPosted: Fri Jun 07, 2019 11:06 am    Post subject: Reply with quote
T8 wrote:
Desert Dragon wrote:
....... If they’re used as dd or worse just sat around in my experience they cost a fair chunk more to run than their cooking siblings and there’s lots of owners who buy and run them and when/if anything goes wrong the cars are beyond their means to fix properly.
I've had mine for over 4 years and done 23k miles. Apart from routine servicing being a little bit more expensive I can't think of anything that mine has cost that would have been cheaper if I'd been running a Carrera.
Like any car there will always be those that have been run on a budget and have been a bit neglected but I think this would account for a very small percentage of 997T owners. Unlike the 996T they never came down to the sort of money that would have attracted those with a shoestring budget.
What would yours have cost to run if you had not had an OPC warranty out of interest? If running on a budget would you run without a warranty? Judge
Desert Dragon
PostPosted: Fri Jun 07, 2019 11:12 am    Post subject: Reply with quote
easternjets wrote:
Desert Dragon, I think your painting a particularly negative picture of Turbo's and their owners.
Porsches own service schedule for 997 turbo is not up to scratch. I service every year and always something to do at each service. Bi annual as per official OPC servicing schedule leads to cars not being well looked after IMO. Personally I'd still PPI even if from an OPC with a two year warranty which is how I'd buy a turbo. Whats the harm? Do you think the OPC sales man can tell you if a car is original panel or the VTGs in good condition?
I'm a turbo owner by the way
Smile
PostPosted: Fri Jun 07, 2019 5:21 pm    Post subject: Reply with quote
I reckon that the cost of my warranty over the last 4 years has just about matched the cost of parts/work I've had done excluding the replacement gearbox so I'm about £10k up on the deal. What I've also had is complete peace of mind.
If I hadn't had the warranty the misty leak causing the gearbox replacement would have been cleaned off and if it had reappeared I would have got 9e to replace the gasket with their own item for about £1.5k.
I don't think I'd run any 911 without an OPC warranty and I certainly don't think I'd own one if I couldn't afford to maintain it properly.
easternjets
Watkins Glen
PostPosted: Fri Jun 07, 2019 5:38 pm    Post subject: Reply with quote
Correct me if I'm wrong but I can't recall any Turbo owner telling us that their cars engine went pop or their gearbox failed.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
Scholester
PostPosted: Sat Jun 08, 2019 7:40 am    Post subject: Reply with quote
Smile
Hello fellow Turbo owner.
I guess it's tricky to say what's correct and what's incorrect in the way of servicing. The use of these cars has changed dramatically from when they first rolled out of the showroom and were mostly being hammered up and down Autobahns by business men who cared little for the carful enthusiast that would own the car some years later.
I stick to the Porsche scheduling on my car as I only drive it a few hundred miles per year (only ever in good weather) and the used oil comes out like new. For others affording the car more/heavier use then I can see sense in the decision to 'over-service'.
The question to PPI or not should always be yes - do it for piece of mind - but I didn't! I instead rang the OPC that had recently carried out a major service and the previous supplying specialist that had carried out some warranty work (rad and clutch) for their take on the car as it would have been fresh in their memory.
Had I been closer to the car (we were 350 miles apart) and PPI had been easier to organise then I would have gone down this route. In my case it was £400 saved but I was lucky to have the professionals take on it for free. I have swapped out the original exhaust and cats for quality Kline units, replaced the tandem pump cover whilst I was at it and fitted Zunsport grills but none of this work was actually required.
jboy
PostPosted: Sat Jun 08, 2019 9:24 am    Post subject: Reply with quote
Thanks for the continued advice. Without wishing to spook the lot of you who no doubt think I’m crackers, I have decided to stay in the 996 family - and have agreed a deal in principle for a 996 turbo. Mine drives beautifully and I actually like the interior and overall styling. Saving 15k in the process is another factor, of course, as money no object I would definitely take a 997.1 turbo. The advice re the PPI though applies regardless, so thanks - this will be done! I expect to be able to report back midweek on my thoughts on changing from the c2 Carrera to a turbo although it will be in a different sub forum now!
PostPosted: Sat Jun 08, 2019 9:42 am    Post subject: Reply with quote
An interesting development jboy.
As an ex 996T owner I can appreciate your point of view. When I changed to my 997T I started a comparisons thread which ran for a quite a while.
It may be of interest to you.
See --> 996T v 997T Comparisons
Everything that has been said about getting a thorough PPI done on a 997T is even more relevant to a 996T as the car will be several years older. If you find one that has had all of the mileage related stuff done and has 'consumables' recently replaced, or the replacement cost factored into the buying price, you should be fine.
Good Luck Thumb
cheshire911
Estoril
PostPosted: Sat Jun 08, 2019 12:32 pm    Post subject: Reply with quote
A good decision! If I traded my turbo for a replacement porsche turbo, it would only be a 997.2 with the PDK box but better still the 991 Turbo S which is an absolute beast of a car. Not wishing to distract or subtract anything from those who went 996 Turbo to 997.1 Turbo, I could not see a premium for this trade in models - but then again I do have a 6 speed manual box car with the factory X50 option pushing out 450 bhp instead of the stock 420 bhp.
Mine was just serviced at OPC this week - absolutely no advisories or additional work through the comprehensive vehicle health check. Just turned 40k miles. OPC remarks always that it is a stunning car and drives superbly when they take it for the service test ride - the handling was set up by Centre of Gravity back in 2015 and they found the car's geometry on the test ride beautiful.
My advice to the OP would be "go for the very best car you can afford, and it is false economy to buy a car that requires additional work - the estimated costs are rarely the final costs because once they start on those faults, other faults invariably appear out the woodwork." The 996 Turbo is a beautiful analogue car - but age is against it and there are lots of high mileage dogs out there needing money spending on them - all of which can be identified through a PPI.
Don't be surprised if you get an A4 sheet of paper listing work required when you have a PPI. What you do with that list is up to you - walk away or barter and negotiate the price down and proceed with the purchase.
996 2002 X50 Turbo Manual
jboy
PostPosted: Sat Jun 08, 2019 10:38 pm    Post subject: Reply with quote
Excellent reading above and in T8’s thread - thanks!
isysman
PostPosted: Tue Jun 11, 2019 9:47 am    Post subject: Reply with quote
Glad you see you should always get a PPI on P-cars. Got one on my 2013 Boxster recently. Came back with quite a few advisories even though the car looked mint. Luckily the main one, 'bolts on exhaust heavily corroded' was going to be resolved as I already planned a sports exhaust to be fitted.
911 GT2RS Build & 981 Boxster S
Sold ~ 987 Boxster S 3.4, 997.1 3.8 Cab, 987 3.2 Boxster S, 986 Boxster 2.5
Goto page Previous  1, 2
Page 2 of 2
