997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
Tombri
PostPosted: Wed Jun 05, 2019 12:06 pm    Post subject: Tracing leak in 993 windscreen washer system Reply with quote
Whilst at Center Gravity I noticed that my windscreen washer fluid was leaking.
With the front left wheel arch liner removed there was a small hole (looked like it was made by a drill piece from above) through which the fluid was dripping.
It does not empty the tank but many litres comes out if the tank is filled.
How easy is it to get to the pipe from the filler cap to the bottle?
Any ideas most welcome. Dont know
Golf R
RS6 Avant - Sold
944 Turbo - Sold
944 S - Sold
924 Lux - Sold
Cameltoe & Heel
PostPosted: Wed Jun 05, 2019 3:12 pm    Post subject: Reply with quote
Was the tank full?, if so may just be from the overflow pipe?.
Trev
Tombri
PostPosted: Thu Jun 06, 2019 8:52 am    Post subject: Reply with quote
No Trev, it was not full and there must have been a litre that came out.
I suspect the pipe from the filler to the tank is leaking somewhere but I don't know how to get to it as it is in the most inaccessible place.
Even when it stops leaking there is still enough fluid in the system to work - and work without any delay when you pull the stalk, so not sure quite what is happening... Question
Golf R
RS6 Avant - Sold
944 Turbo - Sold
944 S - Sold
924 Lux - Sold
Cameltoe & Heel
PostPosted: Thu Jun 06, 2019 9:21 am    Post subject: Reply with quote
Yes the filler pipe is right up in the top of wing so very difficult to access, it's unlikely to be an issue with that as you said the tank was part full.
Take your headlight out and check that water isn't escaping at the pump/s, they have rubber seals that get full of crap,
Trev
Tombri
PostPosted: Thu Jun 06, 2019 10:00 am    Post subject: Reply with quote
Thanks Trev - good idea.
There is just this mysterious hole in the wheel arch liner, through which the fluid leaks and I just wonder if a pipe has been nicked by a drill piece.
But I will do as you say - thank you. Thumb
Golf R
RS6 Avant - Sold
944 Turbo - Sold
944 S - Sold
924 Lux - Sold
