997 : 2004- 69
996 : 1997-2005 35
Boxster : 1997- 22
NLW73
PostPosted: Wed Jun 19, 2019 8:56 am    Post subject: Reply with quote
Hertsdriver wrote:
Id also previously cleaned up the old 'carerra' badge that id taken off and painted it gloss black with new double sided foam so that went on too which was satisfying as they are at least £50 to buy
ref the air con condensers I painted mine in Black with spray paint as the new ones stick out like a sore thumb Wink
997 C2s Schwarz
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Fri Jun 21, 2019 10:37 pm    Post subject: Reply with quote
Got a new drive belt today (plus some jack pads 👍 from a forum member) from car parts for less (Conti), the old one had been checked and was deemed ‘ok’, but it hadn’t been changed for a long time... got the old one off and compared the 2, it was obvious that the new one was far more pliable than the old, and once installed the new belt was a lot quieter, however I think definitely one but possibly 2 of the idlers need replacing....
 Filesize:  721.55 KB
 Viewed:  969 Time(s)
 Filesize:  850.86 KB
 Viewed:  978 Time(s)
Hertsdriver
PostPosted: Fri Jun 21, 2019 10:42 pm    Post subject: Reply with quote
Open Youtube Page
Cannop
PostPosted: Sat Jun 22, 2019 9:21 am    Post subject: Reply with quote
The top one sounds bone dry and gritty but none of them seem great, I'd replace all three for peace of mind. Check the alternator freewheel pulley is functioning too.
Full fat Hartech'd C2S Manual
Hertsdriver
PostPosted: Sun Jun 23, 2019 9:22 pm    Post subject: Reply with quote
Yeah I’ll probably do all 3... nothings cheap Laughing Laughing Laughing
Got the back wheels off again today and adjusted the handbrake, then gave it another full clean and wax.... Thumb
 Filesize:  1.42 MB
 Viewed:  837 Time(s)
Hertsdriver
PostPosted: Thu Jul 04, 2019 11:03 am    Post subject: Reply with quote
Alternator pulley seems to be good Thumb
Did some investigation on cost to replace the 3 the Idler/tensioners: 99710211700, 99710211800, & 99710211900
OEM from OPC: £190.18 (with 10% PCGB discount)
Hamberg Design911: £162.19 (with 5% 911uk discount)
But further investigation and I found this excellent thread in the 996 section giving the specs for the bearings:
http://911uk.com/viewtopic.php?t=116879&start=0&postdays=0&postorder=asc&highlight=
So having identified that mine are the type with the metal housings that should mean I can extract the old bearings I ordered all 3 SKF branded bearings to replace the noisy ones:
https://www.bearingbasement.com/p/bearings/angular-contact-bearings-b-double-row/3202a-2rs1tn9mt33-skf-bearing-double-row-angular-contact-sealed/
Cost: £66.46 inc VAT and delivery thumbsup
Once they arrive I will post up a how to on pushing the old ones out of the pulleys and pushing the new ones in, which will no doubt be a body with sockets and a vice as I dont have a press Floor
If anyone here needs it I have a 10% discount voucher code for the above bearing site for the next 30 days, pm me if you want it Thumb
Hertsdriver
PostPosted: Thu Jul 04, 2019 11:13 am    Post subject: Reply with quote
Took the 911 camping with the kiddies as the second car because obviously my wife couldn't fit everything she felt she needed into just one car..... frustrated and am now going to buy some roof bars to make the 911 a bit more practical in weekend situations Razz
Have also bought a second hand Alpine carplay head unit from a chap on here (thanks DieselDave!) and got a chance to fit it yesterday ('working from home on the kids sports day.... dont judge me Laughing).
My car is non Bose so I once again used the excellent search function and followed the advice/guide by matsmith749:
http://911uk.com/viewtopic.php?t=111204
Sound is much improved over the PCM and I've also gained a new cubby hole as have removed the NAV and CD changer units from the frunk, so a place to stash the oil topup bottle Thumb
Now on the lookout for a cheap compatible reversing camera..... Floor
 Filesize:  681.79 KB
 Viewed:  638 Time(s)
rob_p
PostPosted: Thu Jul 04, 2019 8:49 pm    Post subject: Reply with quote
Very nice and a great thread.
You might also want to get the aircon buttons refurbished.
There is a service advertised on eBay, based in wales.
991.1 C2 (no mods, yet)
Jeep Grand Cherokee WK2
Ex Porsche Boxster 986
Ex Mazda MX5 mk1
Hertsdriver
PostPosted: Thu Jul 04, 2019 9:25 pm    Post subject: Reply with quote
Thanks! Yep they are on the list.... (does it ever end? Laughing )
So my bearings turned up today, so I whipped the air filter housing and set about removing the top pulley, first hurdle how to undo the torx head bolt? Bodged it with a tight fitting socket (sorry...) think it was 9/16? Anyway it turns out I have the type of pulley that you can’t remove the bearings on, do the new bearings will go back, luckily they offer a full refund Thumb
Anyway while the pulley was off I pulled the seals and inspected the bearing, could not feel any noticeable wear, but it was dry as fook, so I cleaned it through, and pushed new high melting point grease into both sides and popped the seals back on, it’s now not noisy at all, although I don’t expect that will last so I’ll probavly order a new set up
Hertsdriver
PostPosted: Mon Jul 08, 2019 8:54 am    Post subject: Reply with quote
Nice little job crossed off the list, cleaning up my rusty looking nuts.... Embarassed
1 can of silver smoothrite, some masking tape and a bit of a wirebrushing for a big improvement Thumb
Before :(
 Filesize:  211.14 KB
 Viewed:  501 Time(s)
 Filesize:  140.86 KB
 Viewed:  501 Time(s)
 Filesize:  149.11 KB
 Viewed:  513 Time(s)
After :)
 Filesize:  166.17 KB
 Viewed:  513 Time(s)
Hertsdriver
PostPosted: Wed Jul 10, 2019 8:27 am    Post subject: Reply with quote
Got home to find another package waiting for me: 3 idlers from Rockautos.com
Plan is to replace the noisy idlers and the tensioner, ive bought 3 basic units and will reuse the shims/washers/bolts from the units that come off. Waiting for the set of female torx sockets to arrive and then will fit at the weekend.
Man maths says I saved another £100 over OPC prices after all costs paid out, the voice inside my head wants to start a file to document the saving that can be made if you avoid the 'porsche tax'... Thumb
 Filesize:  29.11 KB
 Viewed:  346 Time(s)
 Filesize:  106.93 KB
 Viewed:  352 Time(s)
yavor
PostPosted: Wed Jul 10, 2019 9:06 am    Post subject: PASM and Sport Reply with quote
Similarly to you my must-haves are the adaptive dampers (PASM) and the sport-chrono. I realise it narrows down the cars a lot and I am wondering how useful would be the sport-shrono?! Can you not change the throttle response to a sharper lever without it at all? Are those different maps it activates so different?
Hertsdriver
PostPosted: Wed Jul 10, 2019 9:42 am    Post subject: Re: PASM and Sport Reply with quote
My car has PASM but not chrono, my understanding is that the responsiveness part of sports chrono can be retrofitted, but not the clock/binnacle, although there is a school of thought that all this does is alter the 'curve' of the throttle response, and that the same result can be had by burying the throttle... Question I would have thought it more beneficial on a tiptronic than on a manual...
yavor
PostPosted: Wed Jul 10, 2019 2:50 pm    Post subject: Reply with quote
Cheers. Yes, this how I am imagining it as well. It could possibly show some character on a track.
Hertsdriver
PostPosted: Thu Jul 11, 2019 11:12 am    Post subject: Reply with quote
The female torx socket set arrived yesterday (amazon cheapo special) so I got a free hour last night so decided to tackle the idlers...
Easy enough getting them off, but ran into a slight hitch. The OEM idlers have large diameter 'washers' which cover the bearings front and rear which cant be used with the Dayco units (as they hit the housing), as the also sit between the bolt head and housing they are also spacers, so I had to hunt around for a few washers in my parts bins to make sure that the idlers were spaced out from the block the same as the OEM items. Not a big deal to me as I had some lying around (they need to be a 15mm ID which I think is M14?), but if anyone else is considering using those parts its worth bearing (no pun intended) that it mind... Thumb
I put loctite on the tensioner thread, but non on the other 2 bolts. I googled around a bit for the torque wrench settings and used the following, would be grateful if anybody could point out if these are drastically wrong!
Lower Idle bearing: 17ftlb / 23nm
Upper Idle bearing: 34ftlb / 46nm
Upper Tensioner: 48ftlb / 65nm
Ran the car and it is noticably quieter! Will keep an eye on it all and probably re-tension next week once the car has some miles on it.
 Filesize:  796.61 KB
 Viewed:  231 Time(s)
Hertsdriver
PostPosted: Mon Jul 15, 2019 10:39 pm    Post subject: Reply with quote
Part of the reason I bought a 911 was to prove to my wife that it was a ‘reasonably’ practical car... well it ticks the box of having back seats (for young kids like my 5 & 9 years old maybe...), but I’ve been eying up roof racks and boxes for a while in an effort to give a further option... so look away now if you are offended by this notion, as I’ve got a rack sorted Laughing Laughing Laughing
Research on this excellent forum led me to 2 options:
1. The official Porsche ‘Roof transport system’
2. A combination of Thule parts...
Option 1 certainly appeals in as much as they look aesthetically very pleasing, but rarely come up for sale, are at least double the cost of option2, and also suffer from having the same size ‘feet’ front and back, giving any box that’s strapped to the top a bit of an uphill stance...
So I went for option 2, and got a great deal in the for sale section here.
The kit is a combination of short ‘feet’ for the front, and slightly longer ‘feet’ at the back, to try and level out the curve of the roof and provide a level base for any box to sit on. For anyone considering this the parts are:
2 x Thule 753 feet
2 x Thule 751 XT feet
1 x Thule 3100 fitting fit (specifically for the 996/997)
Traditionally this combo is paired with a set of 118cm wide bars (either square or aero style), but in all the pictures I looked through the bars seemed too big and hung several inches over the edge of the feet. This is even more pronounced on the rear where the design of the roof means the distance between the feet is much narrower than it is at the front. So I put the feet into the roof, had a measure and decide to try a pair of Thule bars 10cm shorter than the 118cm variety that most people use, and although I couldn’t find a reasonably (read cheap) set of the rather tasty black painted version Thule aero bars that are sold, I found a decent suitably cheap set of silver ones that I will spray in basalt to match the car on eBay (£30).
Bars arrived today so it was time to see if my calculations worked... and I think it’s spot on! with maybe a bit to cut down each side on the rear, although that might look weird....???
Now to keep an eye out for a decent used Thule ‘Dynamic M’ roof box, which is identical to the Porsche branded dealer option box (it’s a rebranded Thule box) as I think that style and shape will work best with a 911 if that’s possible..... Floor
 Filesize:  1.15 MB
 Viewed:  118 Time(s)
 Filesize:  1 MB
 Viewed:  118 Time(s)
 Filesize:  1.19 MB
 Viewed:  118 Time(s)
Here you can really see how the rear is a lot narrower than the front
 Filesize:  838.44 KB
 Viewed:  118 Time(s)
Cannop
PostPosted: Tue Jul 16, 2019 7:32 am    Post subject: Reply with quote
Looking good! Thumb I find they're a very useful accessory to have.
However, the official Porsche roof bars don't have the same size feet, they are different lengths to level out any load.
You're correct, they don't come up for sale very often but I was lucky enough to buy mine a few weeks before you bought yours from this very forum Smile
http://911uk.com/viewtopic.php?t=134008
They do cost a bit more though I'll give you that!
Hertsdriver
PostPosted: Tue Jul 16, 2019 7:42 am    Post subject: Reply with quote
Ah right thank you for that, sorry I got the foot size wrong Embarassed
They doo look better than the Thule ones for sure, do you have a pic of them fitted? There’s another set for sale at the same price as yours were, and whilst I am tempted it’s another £150 more than the Thule version Surprised
I’m not sure I’m vain enough to pay the extra (or I’m just too tight Laughing )
Cannop
PostPosted: Tue Jul 16, 2019 7:45 am    Post subject: Reply with quote
I haven't but I'll take a snap next time they're fitted Thumb
Goto page Previous  1, 2, 3
Page 3 of 3
