997 : 2004- 63
Carrera SC : 1977-1983 3
Boxster : 1997- 29
Cayman : 2005- 22
Macan : 2014- 7
Cannop
PostPosted: Sat Mar 14, 2020 9:29 am    Post subject: Reply with quote
berni29 wrote:
Hi
I have enjoyed reading your thread very much. One thing I really do not understand, or in fact believe, is that your main bearings are nearing the end of their life. What makes you think such a thing?
Berni
It's not nailed on that they're nearing the end of their life but it is likely. Here's what Baz has to say on the subject in this thread. If anyone has definitive hard data on the subject it's Baz!
"As a very general rule of thumb (and prone to exceptions) crankshaft bearings are usually worn to under the white metal bearing surface in the highest wear areas (about 24 degrees after TDC) by 75K and cranks too worn to re0use after 150 K (if they are still running by then)."
Full fat Hartech'd C2S Manual
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8
Page 8 of 8
