991 : 2011- 19
997 : 2004- 76
996 : 1997-2005 35
993 : 1993-1998 7
Cayenne : 2003- 4
Milo72
PostPosted: Fri May 31, 2019 6:32 pm    Post subject: Handbrake explosions.... Reply with quote
Fortunately I was only a mile from home when this happened and fortunately my car is a tiptronic so it won’t roll away before I fix it.
997.1 C2S Tip.
 Filesize:  1.35 MB
 Viewed:  1351 Time(s)
 Filesize:  1.35 MB
PostPosted: Fri May 31, 2019 6:49 pm    Post subject: Reply with quote
The handbrake shoe material has detached from the shoe , this tends to lock the wheel on that side ..
How bad is the hub ???
Can you get any pictures of that please .
I've seen this a few times on Boxsters .. 1 of which required a new hub due to the damage .
Indys check the handbrake shoes on a major .. OPC don't .. but thats still every 4 years so a long time between checks .. but this is a rare fault .
Milo72
PostPosted: Fri May 31, 2019 7:02 pm    Post subject: Reply with quote
I can see it’s rubbed away a bit of the hub, especially where the handbrake retaining springs push in, but other than that it doesn’t look too bad.
997.1 C2S Tip.
 Filesize:  690.71 KB
 Viewed:  1333 Time(s)
PostPosted: Fri May 31, 2019 8:10 pm    Post subject: Reply with quote
My concern is the block the shoes sit on .. if it's still flush then all's good .
Right side of that image .
That was the place the Boxster damaged .. it the shoes don't have a flat base to sit on then basically it needs a new hub .
Milo72
PostPosted: Fri May 31, 2019 8:24 pm    Post subject: Reply with quote
Ahh I see... I’ll get all the bits and see how it looks, rather not have to get a new hub as I’ve just had all the suspension set up.
I’m glad it’s auto and passed it’s MOT 2 weeks ago as it buys me a little bit of time if it’s worst case scenario.
As always... Thanks for your advice.
997.1 C2S Tip.
