997 : 2004- 62
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 20
Cayenne : 2003- 7
baldlemur
PostPosted: Tue May 28, 2019 11:34 am    Post subject: MAF sensor fault codes '08 Cayenne S Reply with quote
Hello
Apparently, I have the following fault codes on my 957 Cayenne S 4.8:
P1080 - air mass ahead of throttle valve, partial load (no signal)
P1094 - air mass ahead of throttle valve - implausible (below lower limit value)
P1097 - Mass air flow ahead of throttle valve (MAF1) - implausible (below lower limit value)
Looks like a new MAF sensor is required? Are there 2 sensors on a 957 Cayenne S 4.8 petrol? Is it prudent to replace both at the same time?
I notice that on Design911 the Bosch ones are much cheaper (£170) than OE Porsche ones (£560). Are the Porsche ones worth the extra? Anyone know who makes the OE ones?
Also, from a quick look at youtube, changing the sensor looks like a DIY job...am i right? Would the codes have to be cleared at OPC after replacement of the sensor(s)?
Thanks in advance
John
Seal Grey 2003 996 C4S Tiptronic
Dark Olive 2007 facelift Cayenne 4.8 S
PostPosted: Tue May 28, 2019 7:28 pm    Post subject: Reply with quote
V6 will have x1 maf sensor whilst a V8 will have two .. i would guess that MAF1 is bank 1 so left hand side facing the car from the front .
The fault codes do seem to indicate a maf sensor fault .. im dubious an air leak would cause those readings .
yes its a diy job .
i replace whats broken or is indicated as such then test , replacing both is not warranted atm.
I would prefer the fault codes to be cleared as that will reset the adaptations as well .
Be aware a maf fault code does not always indicate a MAF Sensor fault . .
I'm afraid i use porsche parts so can't comment on non OEM.
Indy Mechanic .
baldlemur
PostPosted: Tue May 28, 2019 9:25 pm    Post subject: Reply with quote
Thanks deMort. Helpful info as always!
baldlemur
PostPosted: Thu Jul 04, 2019 10:22 pm    Post subject: Reply with quote
UPDATE
Replacing the MAF sensor worked. All fault codes cleared. Smile
