997 : 2004- 66
996 : 1997-2005 34
964 : 1989-1993 1
Cayman : 2005- 20
Cayenne : 2003- 7
Macan : 2014- 6
kurlykris
PostPosted: Wed Aug 21, 2019 6:56 pm    Post subject: Reply with quote
Here`s the diagram of the pipework, the rear hoses are the same style as the front ones that fail, it may be the same fix if you are lucky Thumb
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
sillysally1
PostPosted: Wed Aug 21, 2019 7:23 pm    Post subject: Reply with quote
Awesome, thank you for that. Will take a good look tomorrow and post back what I see.
Ghianightmare
PostPosted: Wed Aug 21, 2019 8:03 pm    Post subject: Reply with quote
sillysally1 wrote:
Ok, maybe I’m not being totally truthful there as the window is starting to irritate me just enough to start thinking about doing something about it (Apart from applying rubber treatment to the seal but it squeaks even when the door is open and with the scraper seal on the outside pulled away)
Google “gumi pflege”. It is what the German manufactures all use. It is the best stuff for rubber seal sqeaks/rattles/creaking noises. Don’t put silicon based products on them
2002 Seal Grey C4S
sillysally1
PostPosted: Wed Aug 21, 2019 8:10 pm    Post subject: Reply with quote
Got it Smile...but it didn’t work so took the door apart and lubricated where the cable ran. The squeak has gone but it’s still a bit slow, I think the angle of the glass against the rubber could be it as it’s faster when the door is open
wasz
1999 Porsche 996 Carrera 2
PostPosted: Thu Aug 22, 2019 4:08 pm    Post subject: Reply with quote
You can adjust the door glass angle from underneath the door, look for the rubber bungs to pop out.
The power steering hose can probbaly be fixed by a hydraulic specialist like Pirtek in situ rather than dropping the engine.
sillysally1
PostPosted: Thu Aug 22, 2019 6:58 pm    Post subject: Reply with quote
Just had a look and there’s a drip from under the bracket. There must be a join under there so need to take that plastic bracket off tomorrow and see what’s what.
 Filesize:  73.69 KB
 Viewed:  1636 Time(s)
sillysally1
PostPosted: Thu Aug 22, 2019 10:16 pm    Post subject: Reply with quote
I think it’s this join (top red circle), might be some kind of O ring if I’m lucky
 Filesize:  420.46 KB
 Viewed:  1605 Time(s)
sillysally1
PostPosted: Fri Aug 30, 2019 6:23 pm    Post subject: Reply with quote
Just picked this up from Euro Car Parts (£151.46)...now just need to find the time (and instructions) to fit it...or someone else to do it. Getting bored of topping up
 Filesize:  664.67 KB
 Viewed:  1425 Time(s)
sillysally1
PostPosted: Fri Aug 30, 2019 7:25 pm    Post subject: Reply with quote
And does the fuel line have to come off?
This video says it does (US video so has some other parafanalia attached which mine doesn’t)
https://youtu.be/nT2A-G0uinE
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Fri Aug 30, 2019 7:36 pm    Post subject: Reply with quote
I changed the tank on my '98 C2. Just dropped the engine a bit from what I remember, no fuel lines off.
sillysally1
PostPosted: Fri Aug 30, 2019 7:45 pm    Post subject: Reply with quote
I won’t be dropping the engine, if it needs that then it will have to go to a garage unfortunately nooo
NLW73
PostPosted: Sat Aug 31, 2019 9:35 am    Post subject: Reply with quote
I had the issue with pas lines on old 996
The issue is one line is high pressure and the other is low pressure. They have probably corroded through age and use so will need replacing
Absolute pig of a job and had to have new lines in the end. Well I say new as Porsche don’t make them anymore so got some used ones from 9part
Am afraid mine was engine out job to do the lines as there is just no room to get out or re route the new ones in.
Good luck and hope it’s not as bad as mine was
997 C2s Schwarz
sillysally1
PostPosted: Mon Sep 02, 2019 5:24 pm    Post subject: Reply with quote
Thank you, really hoping it doesn’t come to that as I have to maintain a strict budget. Will post the spend to date later this evening.
MisterCorn
PostPosted: Mon Sep 02, 2019 5:47 pm    Post subject: Reply with quote
sillysally1 wrote:
It isn't hard, support the engine on a jack. Undo the rear mount nuts, and lower the engine a couple of inches. Nothing is disconnected from the engine.
http://911uk.com/viewtopic.php?t=119444&highlight=expansion+tank
sillysally1
PostPosted: Mon Sep 02, 2019 5:57 pm    Post subject: Reply with quote
MisterCorn wrote:
sillysally1 wrote:
It looks so tantalisingly like it would just come out Sad
MisterCorn
PostPosted: Mon Sep 02, 2019 6:02 pm    Post subject: Reply with quote
sillysally1 wrote:
MisterCorn wrote:
sillysally1 wrote:
That is because you can only see part of it. Trust me, it won't.
sillysally1
PostPosted: Mon Sep 02, 2019 6:11 pm    Post subject: Reply with quote
MisterCorn wrote:
sillysally1 wrote:
MisterCorn wrote:
sillysally1 wrote:
I’ll post my spend to date in a minute and you’ll see how much needs doing...might as well hand it into a garage and bite the bullet.
BTW, got the replacement one from Eurocarparts, anyone heard of any problems with those?
sillysally1
PostPosted: Mon Sep 02, 2019 6:40 pm    Post subject: Reply with quote
Porsche spend to date (5 months and 2000 miles)
Collection of car from buyer - £260
Tyre (Pirelli P Zero from Black Circles) - £142
Tracking - £42
Internal cubby hinge fix kit - £32.36 from eBay with instructions
Front reflector - £30 from eBay (new)
Fan belt - £16
Engine hood strut - £30
Air conditioning pipe replacement - £310
Air conditioning re-gas - £60
Front number plate backing from eBay - £10
Door innard fix - £15
Bleed nipples from eBay - £22 (not yet fitted)
Under front bonnet grommets from eBay - £9.98 (not yet fitted)
Wipers - ??
Interior bulbs - £10.98
Number plate lights - £61.27
New number plate - £20 (not yet fitted)
Expansion tank - £151.46 (not yet fitted)
Underbody lining wheel arch cover - £40 (not yet fitted)
Rear bumper rail - £34 (not yet fitted)
Cost to date - £1297.05
Including purchase price - £7847.05
sillysally1
PostPosted: Mon Sep 02, 2019 8:18 pm    Post subject: Reply with quote
New video uploaded to YouTube today too...exciting (ish) news!
kurlykris
PostPosted: Mon Sep 02, 2019 9:09 pm    Post subject: Reply with quote
Are you sure that the £150 expansion tank is the correct one, year 2001 onwards, the more expensive one £229.99 up to year 2000 on ECP is the correct one I think Question They are different tanks Grin
You need a Porsche themed flat cap in your videos, you know it`s da rulez Grin
Goto page Previous  1, 2, 3 ... , 14, 15, 16  Next
Page 15 of 16
