991 : 2011- 19
993 : 1993-1998 7
Cayenne : 2003- 4
sillysally1
PostPosted: Mon Jul 29, 2019 6:20 am    Post subject: Reply with quote
I’ve fitted some new ones...but they still don’t work :-(
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Tue Jul 30, 2019 5:21 pm    Post subject: Reply with quote
SS1 - could it be simply unplugged from the last time the rear bumper cover was removed?
Just a few minutes to check.
Failing that, perhaps the gear box pick up / reverse switch might be knackered.
sillysally1
PostPosted: Wed Jul 31, 2019 6:48 am    Post subject: Reply with quote
Thanks Jonno, it does look like the bumper has been off in the past (as the trim just under the hood is missing)
I’ve not started any investigation at all yet but intend on having a look on Friday. Thanks for the tip...are there any other symptoms I should look for? I.e. reverse lights not working.
maldren
PostPosted: Wed Jul 31, 2019 4:59 pm    Post subject: Reply with quote
IIRC the rear light clusters share a single feed and plug so I would expect all or nothing there. It's also above the bumper so that would not affect it.
Mike
sillysally1
PostPosted: Wed Jul 31, 2019 8:30 pm    Post subject: Reply with quote
Had a quick look at the number plate lights tonight. The other lights work fine (including reverse lights) and the alarm for leaving the lights on works too. I’ve cleaned the connectors to the lights and the bulbs are new. I haven’t checked fuses but I guess something else wouldn’t be working as well if a fuse was gone for lights...wouldn’t it? There’s a wire that goes through a grommet our from the engine bay to under the bumper which must be the wire. There’s no other plug after that apart from the ones that connect to the lights is there?
maldren
PostPosted: Wed Jul 31, 2019 8:53 pm    Post subject: Reply with quote
Do you have an electrical meter, they,re really quite cheap nowadays and they make fault finding much easier?
Mike
sillysally1
PostPosted: Wed Jul 31, 2019 9:02 pm    Post subject: Reply with quote
Spooky, was just looking at where I can pick one up tomorrow or get one from Amazon Smile
eabeukes
1999 Porsche 996 Carrera 2
PostPosted: Thu Aug 01, 2019 8:26 am    Post subject: Reply with quote
I suggest Fluke (if you can afford it), or Extech, Schneider Electric or Innova for budget options. The Amazon el-cheapo's are great for low voltages but I wouldn't trust them on HV. And electricity is not something you want to Star Wars with. Ask me how I know.
arry wrote:
To hell with resale; drive it hard, enjoy it, enjoy maintaining it.
sillysally1
PostPosted: Thu Aug 01, 2019 9:05 am    Post subject: Reply with quote
I’m too scared to ask!
maldren
PostPosted: Thu Aug 01, 2019 4:15 pm    Post subject: Reply with quote
I bought mine from Maplin, sadly no more.
Mike
P0tential
PostPosted: Thu Aug 01, 2019 6:16 pm    Post subject: Reply with quote
My lisence plate lights were badly corroded when I bought the car. Ended up having to solder on new spade connectors and getting new lights. I guess that's what 20 years will do to a car!
996 Carrera 4 Coupe
sillysally1
PostPosted: Thu Aug 01, 2019 7:18 pm    Post subject: Reply with quote
Picking up a multimeter tomorrow, will keep you posted
sillysally1
PostPosted: Mon Aug 05, 2019 9:36 am    Post subject: Reply with quote
It looks like it’s disconnected behind the bumper Sad
sillysally1
PostPosted: Mon Aug 05, 2019 9:45 am    Post subject: Reply with quote
Is it normal for the rear speakers to pop out like this? They don’t sound great either but I think that’s just the way they are
 Filesize:  694.59 KB
 Viewed:  1610 Time(s)
heed
PostPosted: Mon Aug 05, 2019 11:45 am    Post subject: Reply with quote
Licence plate lights failing in wiring behind bumper is not uncommon on 996. At least that’s what I was told recently.
It’s not that bad taking the rear PU off. Bit of a mission for some lights though!
'04 996 C4S, arctic silver, graphite grey
sp1ke
PostPosted: Mon Aug 05, 2019 5:58 pm    Post subject: Reply with quote
no those speaker don't look seated correctly. They're easy to remove, but can sometimes take a bit of finessing to reseat correctly.
btw you can get a set of Alpine replacements for about £40 on Amazon.
https://www.amazon.co.uk/Alpine-SPG-10C2-10cm-2-Way-Speakers/dp/B002XCNPMS/ref=sr_1_1?keywords=alpine+spg-10c2&qid=1565027487&s=gateway&sr=8-1
They'll sound much better. You'll need some connectors:
https://www.amazon.co.uk/gp/product/B01KQG3MK2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
& you can recycle the original speakers to make mounting brackets:
https://www.youtube.com/watch?v=W0LPyCoq5k8
2001 996.2 C2
sillysally1
PostPosted: Mon Aug 05, 2019 6:07 pm    Post subject: Reply with quote
Thanks dude, will definitely check that out later!
sillysally1
PostPosted: Wed Aug 21, 2019 4:14 pm    Post subject: Reply with quote
Argh! Drip from a split power steering hose Sad
kurlykris
PostPosted: Wed Aug 21, 2019 6:26 pm    Post subject: Reply with quote
Where abouts is the split ?
Is it the "usual suspect" where the hose changes to a hardline into the steering rack, the aluminium ferrule corrodes and splits apart Question
If so, two jubilee clips over the hose and clamp it down onto the hard line Thumb
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
sillysally1
PostPosted: Wed Aug 21, 2019 6:44 pm    Post subject: Reply with quote
I think it’s much worse...the drip lands on the floor under the right hand side exhaust box (when looking at the car from the back)
I can just hear the garage now “that’s an engine out job mate”
Goto page Previous  1, 2, 3 ... 13, 14, 15, 16  Next
Page 14 of 16
