ch3tman
Well-known member
- Joined
- 8 Dec 2012
- Messages
- 1,079
Hi all,
Can anyone confirm how the front quarter window seal is fitted?
I am hearing wind noise coming through the area highlighted blue, below, when driving.
If I press down on the highlighted area to create a seal (just at the front portion, not the whole length), the wind noise disappears.
- Should it sit very tight against the window?
- Should it be glued?
- Anyone familiar with sources that may be passing air to this area? Maybe it's simply the outer seal?
Thanks in advance!
Thanks in advance!
