997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
H0ME
PostPosted: Wed May 22, 2019 11:21 am    Post subject: wiper arms Reply with quote
Does anyone have a *cheaper* source for replacment wiper arms? They are now crica £300 for the pair from the usual places. These items back in the day were 30-40. Anyone know of a Bosch source?
The part number
993 628 028 01 wiper arm
993 628 028 03 wiper arm
I have attempted to have my exisiting arms powder coated but the finish is poor as it does not seem possible to break the Arm part down i.e remove the two springs and plastic(?) piece that attaches to the nut of the car.
1996 993 C2 Tip
Cameltoe & Heel
PostPosted: Wed May 22, 2019 3:28 pm    Post subject: Reply with quote
Have they just dulled off, or are they functionally failing?.
Have you tried spraying with a simple Satin Black?, I wouldn't go down the powder coat route on them.
Trev
H0ME
PostPosted: Wed May 22, 2019 3:32 pm    Post subject: Reply with quote
Trev
Just pitted and chipped. Annoying as your stare at them constantly.
Agree on the powder coat - it does not work. Thinking of taking it all off back to aluminium and re-spraying.
1996 993 C2 Tip
decgraham
PostPosted: Thu May 23, 2019 12:25 pm    Post subject: Re: wiper arms Reply with quote
Hi H0ME,
The plastic comes off by just lifting it up and gently pulling it off (see pic) As Trev says I'd go with a rattle can after a good prep.
ATB Smile
 Filesize:  64.2 KB
 Viewed:  738 Time(s)
H0ME
PostPosted: Thu May 23, 2019 12:55 pm    Post subject: Re: wiper arms Reply with quote
decgraham wrote:
Hi H0ME,
ATB Smile
Not the cover.... I was talking about the reverse. There is a sort of hard plastic insert that hooks into the springs.
1996 993 C2 Tip
decgraham
PostPosted: Thu May 23, 2019 1:03 pm    Post subject: Reply with quote
Ah sorry didn't know they was another plastic piece.
However I have found the Bosch part numbers for you and one arm on Amazon is £53.15 with free delivery.
https://www.amazon.co.uk/Bosch-3398102632-Wiper-Arm/dp/B0049RFAPU
ATB Smile
 Filesize:  33.67 KB
 Viewed:  706 Time(s)
 Filesize:  33.72 KB
 Viewed:  706 Time(s)
H0ME
PostPosted: Thu May 23, 2019 1:19 pm    Post subject: Reply with quote
ATB Smile
Thanks for Bosch number although not in stock on Amazon. Like a number of the big suppliers they do list the item, make you order and then cancel as no longer available. I’ve had this also on eBay as they are listed on there - but not actually available.
1996 993 C2 Tip
decgraham
PostPosted: Thu May 23, 2019 1:25 pm    Post subject: Reply with quote
Oh that's a shame. When I replaced my front headlight lenses I bought from Bosch direct using their part number and they were a lot cheaper than Porsche.
Thought you might get lucky too, I see that they were discontinued in 2017. You might find a dealer with the odd one in stock if you have a ring around the Bosch dealers. Good luck Thumb
ATB Smile
