997 : 2004- 76
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
Basalt911
PostPosted: Wed May 15, 2019 12:58 pm    Post subject: Brookspeed Southampton? Reply with quote
Anyone use them?
Thinking of swapping over from my current Indy to use them for work going forward
Counter Of Beans
PostPosted: Wed May 15, 2019 1:25 pm    Post subject: Reply with quote
Hello OP, I have used Brookspeed three times in the last few months, once for a big service (plugs, PDK fluid, belts), once when they fitted my Ohlins coilovers, and most recently when they fitted a new exhaust and rear pads/discs for me.
I'd recommend them. Their communication is good - i.e. they tell you before incurring costs, and their work seems competent. They run a couple of race teams so they should know what they are doing.
They could do with bigger premises; their car park is always rammed but I suppose them being busy is reassuring. They are a 15 minute walk from the railway station in Eastleigh so quite easy to get to - just off the M27. Their labour rate is around £100 per hour including VAT.
PM me if you want more feedback.
Cheers, Mike.
2011 Gen 2 Carrera 2 coupe, Ohlins R&T, Arctic / black, low mileage, mint!
pzero
PostPosted: Wed May 15, 2019 1:43 pm    Post subject: Reply with quote
OP, in addition to the above, other positive experiences regarding Brookspeed are available on the site.
Just have quick search.
Here's one;
http://www.911uk.com/viewtopic.php?t=95856&sid=99a54d91863929b3d18ea63402362fbd
991.1 Carrera GTS
Basalt911
PostPosted: Wed May 15, 2019 1:59 pm    Post subject: Reply with quote
Cheers, Mike.
thanks - that's really helpful.
Rossi911
2011 Porsche 991 Carrera
PostPosted: Wed May 15, 2019 2:13 pm    Post subject: Re: Brookspeed Southampton? Reply with quote
Basalt911 wrote:
Anyone use them?
Experiences vary, for their outsourced engine work, their customer communication and management skills are a complete shambles.
But cheaper than OPC's but i'm out.
991Turbo, dont need the S
kas750
Reims
2006 Porsche 911
PostPosted: Wed May 15, 2019 2:49 pm    Post subject: Reply with quote
They did a ppi for me about 6 years ago and were absolutely useless and when challenged about the work they were aggressive in their reply so it’s a no from me.
baldguy
PostPosted: Wed May 15, 2019 3:50 pm    Post subject: Reply with quote
Where are you based?
958 Cayenne Turbo - Amethyst
996 Carrera 4 - Lapis
chaser
2005 Porsche 997 Carrera 4S
PostPosted: Wed May 15, 2019 6:23 pm    Post subject: Reply with quote
I didn`t have a good experience, 7 out of 8 bleed nipples snapped during a fluid change resulted in me having to buy 4 new calipers at a tad over £2k, no discount on a £4+k bill.
997.2 Turbo `10
997.1 C4S `05
996 C2 `02
baldguy
PostPosted: Wed May 15, 2019 6:35 pm    Post subject: Reply with quote
Any decent shop would have removed the calipers...drilled them out...flushed and refitted...
SaintsPaul
PostPosted: Wed May 15, 2019 6:58 pm    Post subject: Reply with quote
Yuk
Basalt911
PostPosted: Wed May 15, 2019 8:10 pm    Post subject: Reply with quote
Ringwood
sounds like too many bad experiences for me
i was hoping to avoid a 3 hour trip to Centre Gravity for my geo set up...any other choices further South?
Jay.
PostPosted: Wed May 15, 2019 11:50 pm    Post subject: Reply with quote
I get my car serviced there yearly and find their service to be great, friendly people and the technicians always take the time to explain what they've done or what they've found.
My only complaint so far is that they suggested I replaced my top struts as they had "collapsed" but after inspection (and a second referral) they certainly don't need replacing yet (just some wear), so that would have been a grand or so I didn't need to spend.
Unfortunately if you're in Ringwood I don't think there's many other decent Specialists within a reasonable distance (other than OPC)
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
Follow me on Instagram! @rb.240z
Richtw
PostPosted: Thu May 16, 2019 2:25 am    Post subject: Reply with quote
Always found them superb and I am really fussy!! Had plenty of work done and no complaints from me!! Massively helpful plus they know how to setup a car properly!!
Very positive from me!
2017 991.2 GTS
2010 997.2 C4S
Basalt911
PostPosted: Thu May 16, 2019 6:45 am    Post subject: Reply with quote
strange, the feedback is really quite polarised....
(Dorset Sports Cars in 3 Legged Cross are who I use at the moment and they're pretty good and know their Porsches. I only fancied a change as I felt a dedicated Porsche shop might be better).
baldguy
PostPosted: Thu May 16, 2019 7:46 am    Post subject: Reply with quote
I use Northway near Theale Reading and have done for many years when I've had Porsche. Ray and his team look after both of mine and they are are very well respected Independant.
I make the 90 mile round trip and have never had bad service from them. my 996 has just had it geomentry set up and is a better car for it.
A 70m trip for you but IMO well worth it...
Counter Of Beans
PostPosted: Thu May 16, 2019 8:11 am    Post subject: Reply with quote
Ah well, if you're comparing Brookspeed to Center Gravity then I'd recommend CG every time. Center Gravity are the best at what they do, although they don't do servicing like Brookspeed.
Anyway, I've made two trips up the A34/M40/M42 to CG and a couple of hours driving each way is well worth it - for a spot on geo then CG are brilliant.
Regards, Mike.
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Thu May 16, 2019 5:51 pm    Post subject: Reply with quote
Why not PM Phil for Jamie's details?
He's local and mobile
monster
PostPosted: Fri May 17, 2019 1:02 am    Post subject: Reply with quote
Just beat me to it - I was going to suggest the same!
Basalt911
PostPosted: Fri May 17, 2019 9:45 am    Post subject: Reply with quote
sorry, who is Jamie?
Counter Of Beans
PostPosted: Fri May 17, 2019 12:13 pm    Post subject: Reply with quote
James Belbin is a mobile mechanic based in Bournemouth; he trades as JMB Automotive. He did a PPI on my car yesterday and seems extremely competent and a nice guy too. Google him or look on Facebook?
Regards, Mike.
