991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 34
Boxster : 1997- 25
Thelaughingmagpie
PostPosted: Wed May 15, 2019 6:13 am    Post subject: 993 Camshaft Cover Gasket Oil leaks Reply with quote
Hello, my 993 is seaping oil from the Camshaft Cover gaskets. I have replaced two covers and OEM gaskets about seven years ago shortly after I purchased the car. I am just seeing what others have done with their 993;-
Replaced gaskets, nuts and inspected camcovers (only replace if worn)
Replaced gaskets, nuts and OEM camcovers
Replaced gaskets, nuts and Rennline/Design 911 camcovers
Replaced gaskets, nuts and Hargett Precision camcovers (Like Jackal on the forum)
I am curious if anyone has experience of the aftermarket Rennline/Hargett camcovers.
decgraham
PostPosted: Wed May 15, 2019 6:26 am    Post subject: Reply with quote
I did mine a couple of years ago along with the other usual leak suspects, see the recent post below 4th one down:
http://911uk.com/viewtopic.php?t=133858
I checked my covers with a straight edge and they were fine, so I just replaced the gaskets and the bolts, all turned out fine Thumb
ATB Smile
Endoman
PostPosted: Wed May 15, 2019 10:49 am    Post subject: Reply with quote
Although I fitted Rennline lower covers they still leaked. When I redid them I used some Molykote on the gasket surface ok atmo.
General concensus is the ally ones are not worth the extra expense.
My currnet leak is from the back of the cam gear, a big O-ring and gasket will have to wait til winter. It's a far more involved job. Cam chain covers are pretty easy to do.
Tobesetc
PostPosted: Wed May 15, 2019 11:32 am    Post subject: Reply with quote
My Indy told me recently that the Porsche parts have been redesigned and now are the best option.
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
stuttgartmetal
PostPosted: Wed May 15, 2019 11:43 am    Post subject: Reply with quote
The heat warps the oe covers.
Get some aluminium ones off Matt @ type911shop.com
Use a suitable gasket selant on the lower ones, such as Hylomar.
Tobesetc
PostPosted: Wed May 15, 2019 11:51 am    Post subject: Reply with quote
My point being that the heat doesn't warp the new design - according to a very well known Indy. I had the same issue and suggested getting the third-party aluminium versions. I was told not to waste my money as the Porsche part is now the best option. Just relaying what I was told.
