997 : 2004- 69
996 : 1997-2005 35
Boxster : 1997- 22
stokie1
PostPosted: Tue May 14, 2019 7:43 am    Post subject: Buying advice - yawn! Reply with quote
pls send me to a previous thread if easier as I am sure this has been done to death
however, I am a newby to this thread having owned 997's before - and been active on that thread - and I am now looking to go classic
looking at a 1982 sc - light blue with the fuchs - coupe with sunroof
its just had an engine rebuild and has done 90k - looks genuine with the service history
I will get the car checked probably but could some of you give me some pointers from your wealth of experience as to the spec it should have and things to check on a first inspection
its on ebay and says owned by a collector
many many thanks indeed
C2s - sold
C4s - bought - and sold
Historic Racer bought
New Rangey Sport - 2019
On the look out ..
Gazc2
PostPosted: Tue May 14, 2019 8:21 am    Post subject: Reply with quote
Rust rust and more rust,checkround the door latches/kidney bowls and sills ask if these have been replaced at any time, corners of the windscreen check for any signs of rust on the inner wings when you open the bonnet, engines are pretty bullet proof, 915 gearbox can be an adventure finding gears however make sure its changing gear without any crunching re-build is big bucks.
An inspection from some knowledgeable is a must
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
PostPosted: Tue May 14, 2019 8:23 am    Post subject: Reply with quote
Looks like all the mechanicals have been done especially the gearbox.
Why another engine build required at that mileage?
Rust/corrosion is the main issue on these especially around the kidney bowls so bodywork needs a good look over.
I've sent you a PM
stokie1
PostPosted: Tue May 14, 2019 8:59 am    Post subject: Reply with quote
appreciate the comments guys
what extras would I want to see on an 82 car - if any
C2s - sold
On the look out ..
