997 : 2004- 74
Boxster : 1997- 14
Cayman : 2005- 15
MattCPR
PostPosted: Sat May 11, 2019 10:14 pm    Post subject: Lazy starter/squeak Reply with quote
Car seems very lazy to start, almost like a low battery but I know this skin the case because I’ve just changed it.
Also it occasionally makes the horrible squeak that a lot of VAG cars make (solenoid not retracting quick enough)
Time for a new starter? Or could it possibly be a loose earth strap? ( not the squeak)
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Thu May 16, 2019 12:41 pm    Post subject: Reply with quote
check the voltage levels in the 1st instance
Get a Porsche Car Insurance Quote
FOLLOW 911UK ON TWITTER
brownspeed
PostPosted: Thu May 16, 2019 4:09 pm    Post subject: Reply with quote
it does sound like the starter on its way out.........…..
2004 997.1 C2S (Hartech rebuilt)
2002 TVR Tamora 3.6
1990 Mini Cooper RSP
Abarth 595
Supersport Mike
PostPosted: Thu May 16, 2019 4:57 pm    Post subject: lazy starter Reply with quote
Its more than likely the battery voltage cable from the battery to the starter over a period of time they corrode
It happened to mine a new cable is £75 and problem solved spins twice as fast now
Mike
MattCPR
PostPosted: Thu May 16, 2019 6:08 pm    Post subject: Re: lazy starter Reply with quote
Mike
What kind of job is it to fit Mike? I will do some voltage checks on it at the weekend and see what I come up with.
PostPosted: Thu May 16, 2019 6:24 pm    Post subject: Reply with quote
More than likely the starter motor .
Never seen an earth lead wether its battery or the engine strap cause this .. it's always possible but i've not yet seen it .
Noise is the bendix sticking .. it can be free off but that's not the slow spin over fault .
Check the cable whilst you at it , burnt / corroded connection on the starter end of the lead and its past its sell by date .
Manual and it's about a 3 hr job to replace the lead .. if you have a Tip though its an engine drop to replace this lead im afraid so circa 10 hrs ish to replace .
MattCPR
PostPosted: Thu May 16, 2019 6:52 pm    Post subject: Reply with quote
Thankfully it’s a manual. I’ll have a look at the weekend. 👍🏻
