997 : 2004- 65
Cayman : 2005- 22
Macan : 2014- 8
Croydon
PostPosted: Sat May 11, 2019 12:44 pm    Post subject: Turbo front bumper instal Reply with quote
For those that have changed their front bumper for the Turbo one:
Is it a direct swap from standard bumper or are the front wheel arch liners and support bracket different? I ask as I’ve read a fitment thread from the US and the guy said he has to buy new parts in order for bumper to be secured correctly.
Parts:
These are the parts I ordered to do a professional install for the euro turbo bumper cover:
1 – 993-504-125-01 liners for front of wheel housing – LH (driver side)
1 – 993-504-126-01 liners for front of wheel housing – RH (passenger side)
1 – 993-505-793-01 liner support bracket
1 – 993-505-794-01 liner support bracket
1 – 993-631-181-00 retaining bow, not necessary
1 – 993-631-182-00 retaining bow, not necessary (these are the metal brackets that are on the factory bumper and if you need them you can take the old ones off of the original bumper and reuse them.
1-- 993-505-543-00 Bumper Trim Piping left
1-- 993-505-544-00 Bumper Trim Piping right
2 – 993-575-740-00 sealing
2 – 993-575-738-00 sealing
2 – 993-575-772-00 sealing – lower (you really do not need this item)
2 – 993-631-141-01 vent drain – splitter bottom drain.
The old ones WILL break when you try and remove them.
999-911-437-40-xxxmm sealing rubber – this is the weather stripping that goes around the wheel housing liners, you will need 8-10 feet. There are also places on the front frame (next to the bumper) of the car that may need this sealing rubber replaced. If so, order 12-15 feet.
Hardware I used: Some of the screws and speed nuts can be reused from the old bumper. However, I would suggest replacing as many as you can or deem necessary. There are some extra nuts and screws here, but you will figure out what they are for, plus it’s good to have a few extras.
12 -- 900-143-159-07 Tap screws for under the bumper and wheel liners
12 – 900-143-113-07 Tap screws 4.2 for under the bumper and wheel liners
6 -- 999-591-850-02 Speed nuts for top of wheel housing liners
2 -- 900-187-103-02 Screws for liner support brackets (993-505-793 & 794-01 above)
18 -- 999-591-699-02 Speed nuts for liner support brackets and…etc.
6 -- 999-591-850-01 Speed nuts for top of wheel housing liners
2 – 900-143-087-00 Screws 4.8x
Thread:https://rennlist.com/forums/993-forum/432684-euro-turbo-front-bumper-install.html
Croydon
PostPosted: Sun May 12, 2019 12:18 pm    Post subject: Reply with quote
So just to wrap this up after a lot of research (you never know when someone will ask the same question).
The parts needed to install a Turbo front bumper to a c2/c4 NB are just the front part of the wheel liners (L+R) and the brackets that hold them in place (again L+R). Those are the top 4 items Listed in the opening post. The rest are universal rubbers and trim, that you’d upgrade if you took your bumper off for a respray etc...
Ian
stichill99
PostPosted: Sun May 12, 2019 7:29 pm    Post subject: turbo bumper Reply with quote
Have you bought a new turbo bumper cover? Where is the cheapest supplier? I am still in a quandry whether to go for rs look or just turbo front bumper. Both look good but a turbo bumper would be a lot less pennies!
stichill99
PostPosted: Sun May 12, 2019 7:31 pm    Post subject: turbo bumper Reply with quote
Croydon
PostPosted: Mon May 13, 2019 6:43 am    Post subject: Re: turbo bumper Reply with quote
I have bought one from eBay via Germany. Its in good condition, no cracks and all the correct holes and grill attachments are in place.
Bumper eBay
wheel liner x 1 eBay
wheel liner x 1 Rose Passion
Bumper supports x 2 Rose Passion
Bumper seals x 2 Type 911
NB C2; I'm going for a standard rear, Turbo front bumper, Turbo S ducts (ones with lights) and the addition when funds of a set of BBS LMs.
Ian
stichill99
PostPosted: Mon May 13, 2019 10:03 am    Post subject: turbo bumper Reply with quote
I can't argue with bbs lm's!
BBS LM
 Filesize:  202.63 KB
 Viewed:  2789 Time(s)
 Filesize:  202.63 KB
Croydon
PostPosted: Mon May 13, 2019 10:11 am    Post subject: Re: turbo bumper Reply with quote
Excellent, did you opt for the norm sizes?
8Jx x 18" ET 52
10J x 18" ET 65
Carnewal sourced?
Ian
stichill99
PostPosted: Mon May 13, 2019 7:10 pm    Post subject: bbs lm Reply with quote
Fronts are 8.5 wide but offsets same as you just posted.
stichill99
Croydon
PostPosted: Fri Sep 20, 2019 1:29 pm    Post subject: Reply with quote
stichill99 i've had a slight change of plan so have the package for sale if you were still toying with it?
This is a full factory fit inc correct front wheel liners and brackets...
Factory Euro Turbo bumper cover with grill
1 – 993-504-126-01 liners for front of wheel housing – RH (pass side)
If interested I can take photos of the package over the weekend. If not I will throw it up in the FS area.
Ian
stichill99
PostPosted: Fri Sep 20, 2019 3:55 pm    Post subject: turbo bumper Reply with quote
Sent you a pm.
MikeRSR
PostPosted: Sun Sep 22, 2019 2:41 pm    Post subject: Reply with quote
Hi Ian, did you sell the turbo bumper kit?
thanks, Mike
1994 993 C2 Riviera Blue
Croydon
PostPosted: Mon Sep 23, 2019 6:25 am    Post subject: Reply with quote
Sorry guys had a busy weekend, ill get photos taken and go through all my receipts in order to put a price on it all.
Ian
Croydon
PostPosted: Fri Sep 27, 2019 9:23 am    Post subject: Reply with quote
UPDATE:
Pics will be taken tomorrow morning. Ill collate all my invoices and put a price on the package too.
Interested parties could PM me (if you haven't already) your emails addresses.
sorry for the delay.
Ian
