991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
eabeukes
1999 Porsche 996 Carrera 2
PostPosted: Fri May 10, 2019 10:51 am    Post subject: 996 Alarm Weirdness Reply with quote
After some recent work to change out the electrical part of the ignition, my keyfobs no longer lock the car. I dont get any honks or beeps to indicate somethings open, and the light flashes on the dash to tell me its all picked up etc. My indie changed the passenger door locks but made no difference.
So far the following happens:
- 3-left turn locks everything but leaves the digital dash on (and radio too unless manually switched off)
- Single left turn only locks the drivers door, nothing else
- Internal switch locks and unlocks the doors
- Windows on both sides drop correctly to open the door
- Alarm system shows key is in synch and the signal is going between them
- I cant feel any damp under the passenger seat
Any ideas on what I can try next?!
arry wrote:
To hell with resale; drive it hard, enjoy it, enjoy maintaining it.
PostPosted: Fri May 10, 2019 7:14 pm    Post subject: Reply with quote
Well .. i'm pretty sure i know whats wrong .. but as i don't have the car i can't confirm it .
Term 86 S is still active .. in other words the car thinks the ignition key is still in the ignition .
If work has been done in that area then its either faulty or the wrong switch pack has been fitted to the ignition barrel / lock ass .
I would connect a tester .. look at the values and if when key removed term 86 S is still active then that would confirm the fault as being the ignition lock switch pack .
Btw .. if i'm right here .. then i'm giving myself a pat on the back .. if i'm wrong ... well .. ill just try again Very Happy
eabeukes
PostPosted: Tue May 14, 2019 6:58 pm    Post subject: Reply with quote
You, sir, are a genius.
While I don't have anything to confirm Term 86 S active, I did spend £6.70 on a legit Audi switch part 4A0-905-849B (note the 'B' - very important that!!!!!) and swapped them over. As if by deMort-gic it's fixed.
Thank you!
jezgreen911
PostPosted: Tue May 14, 2019 7:59 pm    Post subject: Reply with quote
Another gold star for deMort Thumb
Glad it's all sorted, If you don't mind me asking which Indie do you use?
2003 996 C2
Marky911
PostPosted: Wed May 15, 2019 4:04 am    Post subject: Reply with quote
^^^^ Too right.
Not that I wasn’t impressed by Demorts knowledge already anyway, but that above is bloody marvellous.
worship
PostPosted: Wed May 15, 2019 7:42 pm    Post subject: Reply with quote
Can i just say this is one of those faults that when i first came across it many years ago took me rather long time to find .. hence it sticks in my memory as its .. when finally diagnosed AN oh CRAP that's so obvious moment !!!
Glad its fixed and ..
worship Thank you for your help .. you have no idea just how much its appreciated .
