997 : 2004- 76
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
MarkGolf
PostPosted: Thu May 09, 2019 8:30 am    Post subject: iCarSoft Por ii? Reply with quote
Just bought one of these on a whim, kind of thinking I should have just got the Durametric Enthusiast but lets see.
Are they any good? I simply want to read/reset codes and would like to see Actual Values (suspect I need durametric for that level).
Does it do anything special? I found a few vids on youtube but they didn't tend to dive in to the settings, just focused on reading/resetting codes but I spot options to do other things.
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
MarkGolf
PostPosted: Tue May 14, 2019 8:20 am    Post subject: Reply with quote
Got it, it's pretty good actually, can see all sorts of data, it can show you cam deviations, angle, pressure in shocks, although what is odd is that the values seem to remain fixed for some items, such as suspension level sensors, cam devation, they dont change.. So I am not convinced on if the data is correct, also, it did show my rear shocks as having no pressure but when I selected to view the data for front shocks at the same time, it suddenly had data for my rear shocks, if i removed the front shocks from the list, again, they showed 0... So seems a bit flakey.
Also, my car has PDCC, it can't communicate with the module.
I raised a support email but still not heard back...
So I'm on the fence with this icarsoft atm.
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
MarkGolf
PostPosted: Thu May 16, 2019 11:06 am    Post subject: Reply with quote
Support seems to be NON EXISTENT!
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
