997 : 2004- 69
Boxster : 1997- 13
Cayman : 2005- 14
Paulburton9@googlemail.co
PostPosted: Wed May 08, 2019 4:16 pm    Post subject: Car forgetting key Reply with quote
Hi, can anyone advise why after about a week I cant use the key fob to remotely open my 996 turbo, instead I have to manually use the key to open the door. The alarm goes off and then when I turn the car over it turns off the alarm. The key will then work for about another week. The batteries in the key fobs have been changed. Your help would be greatly appreciated. Cheer Paul
PostPosted: Wed May 08, 2019 5:02 pm    Post subject: Reply with quote
Welcome
Isn't this just a low power mode Dont know
Remember my car doing this ages ago, you have to also turn the key in the ignition within about 5 seconds or the alarm will go off.
Have a search on here, the answer will be there I am sure Thumb
What car you got dude Dont know
Bluebird911
PostPosted: Wed May 08, 2019 5:18 pm    Post subject: Reply with quote
This sounds normal. After a week of being locked up, the car goes into sleep mode. It is woken up by unlocking the car manually with the key. However, you must get to ignition point I within about 5 -10 secs or the alarm will sound. from this point, the key remote will work.
If you don't get in within 5 -10 secs, the alarm will sound, but go off at position I or beyond. What you describe sounds normal operation.
Delanor
PostPosted: Wed May 08, 2019 6:28 pm    Post subject: Reply with quote
If I leave mine for a week I get the usual non working remote as the car has gone to sleep as it should, I unlock the car with the key and then turn the ignition on and all is well again but on the odd occasion when I unlock the door after it has gone to sleep the alarm goes off until I cancel it by turning the ignition on.
Del.
The forward thinking traditionalist!
Current - 210 bhp TDCI Ford Kuga 4x4 Sport
Current - Crystal White 40th Anniversary RX-8.
Current - Porsche Carrera Cabriolet in Viola.
PostPosted: Wed May 08, 2019 7:33 pm    Post subject: Re: Car forgetting key Reply with quote
Its normal and its what we class as full shut down mode .
you unlock with the key after 5 days then you have 10 seconds to turn on the ignition before the alarm triggers .. after that the fob will work fine until its left for another 5 days .
Its a method for saving the life of the battery .
Griffter
PostPosted: Thu May 09, 2019 6:07 am    Post subject: Reply with quote
On my 2001 C4 I could also “wake” the car by turning the key in the door lock (unlock / lock). Then it would respond to the fob.
PostPosted: Thu May 09, 2019 8:12 am    Post subject: Car forgetting key Reply with quote
Thanks to everyone who has responded on this. Its been really useful and reassuring! Cheers
