997 : 2004- 74
Boxster : 1997- 14
cvega
PostPosted: Wed May 08, 2019 9:18 am    Post subject: where to get good replacement wheel nuts Reply with quote
for a 996.2.. mine are rusted to hell and look rather appaling.
Ebay has a load of them but I don't trust cheap shiny replacements. Apart from he dealer, where could I get some ? Any recommendations ?
2003 996 C2
2017 Leaf 30kWh
gone: 2010 335d, 2007 Cayman S, 2008 Civic Type-R, 1992 MR2 Turbo ,1994 MR2 N/A
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Wed May 08, 2019 9:32 am    Post subject: Reply with quote
If they are not falling apart, then they can be dramatically improved by a spray over with silver wheel paint from Halfords etc. Keeps them looking good for longer than I expected. Did mine over a year ago, still fine despite a few removals/refits. I used Rust-oleum silver paint, applied with a brush, on the recommendation of a local motor-factors.
I would imagine like for like replacements will rust again with time, so if changing I'd want stainless steel or titanium.
Other retailers available, but for starters...
https://www.design911.co.uk/fu/pt179_434_-cma81-cmo110/Porsche/996--911--1997-05/Wheel-Bolts/
Alex is our resident metallurgist, hopefully he will be along to advise.
Clanky
2007 Porsche 997 Turbo
PostPosted: Wed May 08, 2019 9:37 am    Post subject: Reply with quote
Design Tek bolts. Stainless with a proper taper on the sliding collar.
https://www.design911.co.uk/fu/prod1397/Wheel-Bolts-DesignTek-for-Porsche-Boxster-986-996-997--Pack-of-10-/
They also do a set of locking bolts too.
996 C4s (Gone)
997 Turbo
S3 Daily Driver
Delanor
PostPosted: Wed May 08, 2019 9:40 am    Post subject: Reply with quote
For Porsche parts see Frazerpart
Del.
The forward thinking traditionalist!
Current - 210 bhp TDCI Ford Kuga 4x4 Sport
Current - Crystal White 40th Anniversary RX-8.
Current - Porsche Carrera Cabriolet in Viola.
cvega
PostPosted: Wed May 08, 2019 10:05 am    Post subject: Reply with quote
lightning fast replies, cheers guys
2003 996 C2
2017 Leaf 30kWh
toobusy
PostPosted: Wed May 08, 2019 5:39 pm    Post subject: Reply with quote
I bought these
https://www.ebay.co.uk/itm/16x-WHEEL-BOLTS-PORSCHE-BOXSTER-986-987-981-OE-STYLE-ALLOY-LUG-NUT-STUD-T40/221088443323?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Seem ok...
2003 Carrera 4, KTM, Jota
Jim45
PostPosted: Thu May 09, 2019 12:01 pm    Post subject: Reply with quote
No affiliation..
https://www.world-motorsports.com/titanium-lugs/porsche.html
Have a set on mine they are stunning....had them about a year and still looking great.
Now with a link that works!
04 / C2 / Manual
Pickse
PostPosted: Thu May 09, 2019 6:41 pm    Post subject: Reply with quote
My DesignTek ones started to rust Rolling Eyes so I went with Ti from Acer Racing.
https://www.acerracing.com/collections/titanium-lug-bolts/porsche
So far so good Thumb
Pickse
03 Arctic Silver 996T Tip S
Now 9E38 - An improved! 996T
PostPosted: Thu May 09, 2019 6:50 pm    Post subject: Reply with quote
As part of a Major service we repaint the wheel bolts as standard ..
If you have access to a bench grinder with a wire wheel then it's pretty easy to sand them down .. a bit of primer and then whatever colour of paint you wish.
It will also make the wheel locking nut fit the lockers better once the rust is removed .
just an option anyways .
What i will add .. as i've seen this .. not all aftermarket wheel lockers have a big enough cone .. please make sure the set you buy is actually listed for a Porsche car .. the solid titanium ones with a fixed cone is what i'm thinking here .
mattomg
PostPosted: Sat May 11, 2019 9:50 am    Post subject: Reply with quote
For a tenner you could buy nut covers in a variety of colours & finishes ?
sim996
PostPosted: Sat May 11, 2019 9:56 am    Post subject: Reply with quote
I've studded all my wheels and trapped the spacer between wheel and hub. I used 90mm studs in the back and 68mm in the front, with radius open ended lug nuts from a supplier near me.
The nuts were zinc coated and really cheap, so I'll just replace if they rust. Think they were 1.99 each.
