997 : 2004- 74
Boxster : 1997- 14
Porky C4s
PostPosted: Tue May 07, 2019 9:46 am    Post subject: C4s Cab rear window rubber felt Reply with quote
Hi, has any body had the same problem as me with the window felt on the quarter lights disappearing gradually?
Any body changed those rubbers for new? Or had the felt re done?
Was wondering if it’s a difficult job to change them .
Many thanks for your time
Regards Very Happy
PostPosted: Tue May 07, 2019 6:51 pm    Post subject: Reply with quote
I can tell you its a seperate item but im afraid ive not done one and have no details on how to do it .. my guess is its bonded on .
https://www.deroure.com/diagrams.asp?MAK=3&MDL=26&TBL=2872&SMA=&SMO=0&ST=&SC=0
DR BAL
PostPosted: Wed May 08, 2019 12:16 pm    Post subject: Reply with quote
I had the same problem on my rear drivers side
Window felt had worn away making it look unsightly
I went to opc Solihull the only way they could do it was to
Replace the window, I think it cost about £ 500 quid
Regards
Bal
Porky C4s
PostPosted: Wed May 08, 2019 6:32 pm    Post subject: Reply with quote
Thanks guys for your replies , yes it looks unsightly when there is no marks anywhere else, I’m going to try to get them re coated, I’ll let you know how I get on as 1k is steep to replace perfect windows
worship
rich291
PostPosted: Thu May 09, 2019 8:15 pm    Post subject: Reply with quote
You can just change the rubber, had mine done a couple of months ago. Cost was about £25 per side plus labour. Looks a lot better now. The felt is there to stop any squeaking I think. I understand that the originals were bonded, takes a bit of effort to get them off.
I can confirm it’s the two parts numbered 2a and 2b in Demort’s link.
997.1T
ex Macan GTS
