991 : 2011-2019 0
997 : 2004-2012 1
Boxster : 1997- 22
Cayman : 2005- 14
Gray79
PostPosted: Sun May 05, 2019 3:25 pm    Post subject: Coolant breather thingy Reply with quote
Where should this clip be, I’ve just got the car and it is in the straight up position, but I’m not sure if that’s correct?
 Filesize:  42.03 KB
 Viewed:  557 Time(s)
 Filesize:  24.45 KB
 Viewed:  557 Time(s)
PostPosted: Sun May 05, 2019 4:16 pm    Post subject: Reply with quote
It should lay flat .. the position its in is for bleeding the coolant system .
The rod will move up with pressure in the system so the top picture shows a warm car .
Gray79
PostPosted: Sun May 05, 2019 4:35 pm    Post subject: Reply with quote
I thought it didn’t look right, thanks Thumb
