997 : 2004- 70
Boxster : 1997- 22
Cayman : 2005- 15
Drew1209
PostPosted: Fri May 03, 2019 5:15 pm    Post subject: 18” wheel & tyre weight Reply with quote
I’m looking to get a set of wheels for my car, looking for something relatively light weight. Current alloy and tyre weighs in at 24kg. I did consider GT3 reps speed design but I believe there heavy too although I like the style of them.
Anyone ran the 18” turbo techno sports on a narrow body car and are they much lighter than what I have with the rear being an 1” wider.
I’ve seen a few set of the spoked Panamera alloys on eBay, there only 9” wide on the rear though but I do like them, anyone know the weight of these
steve r
PostPosted: Fri May 03, 2019 6:12 pm    Post subject: Reply with quote
Lots of wheel weights here:
http://www.944racing.de/wheelweights.php
40th Anniversary
coullstar
PostPosted: Fri May 03, 2019 7:32 pm    Post subject: Reply with quote
So the GT3 sport designs are about 13kg a wheel for rear. The panamera are about 10kg per rear.
Going wider also means heavier tyres if you go up to 285 etc.
I like my Panameras.
Drew1209
PostPosted: Fri May 03, 2019 8:43 pm    Post subject: Reply with quote
Thanks for that coullstar, what size tyre you running with the Panameras and I assume you need to run spacers. Your car looks good with them and weight wise that is very light.
